HEI retrofit help
https://slantsix.org/forum/viewtopic.php?t=61755
Author:  alansDart75 [ Thu Dec 21, 2017 10:36 am ]
Post subject:  HEI retrofit help
So, I'm assembling all of the parts now per the various threads (will post pic before install).
But I notice the ballast resistor has 2 terminals on each side.
Do both get hooked together?
Thanks
File comment: Ballast resistor?
Author:  alansDart75 [ Thu Dec 21, 2017 11:11 am ]
Post subject:  Re: HEI retrofit help
Also a bit confused about hooking up FD478 coil. If I go from positive on the coil to B on module...where do I bring the 12 volts in to the coil?
Thanks
Author:  alansDart75 [ Tue Dec 26, 2017 11:43 am ]
I'm really wanting/needing to get the retrofit installed. I have read what I can, and looked at all of the posts...Does anyone have a recommendation how to hook up the FD-478 coil, as it only has 2 terminals. Also, what do I do about a 4 terminal ballast resistor.
So many slant 6 gurus out there...
While I did have two of these growing up, I haven't worked on one in 40 years.
I'm trying to get this baby into peak performance.
Thanks
Author:  Rick Covalt [ Tue Dec 26, 2017 12:59 pm ]
Here is mine on my race car.
Blue wire comes from the +12V from your old ballast resistor or 12 Volt source. This hooks up to the original red wire on the coil plug. I soldered a second wire on the that terminal and ran it on over to the HEI module. Then the Green wires. One runs back into my Tachometer and the other goes to the HEI module. Ignore the yellow wires they are just for the low oil pressure cutoff which you don't have. Hope that helps.
Rick
Author:  alansDart75 [ Tue Dec 26, 2017 1:19 pm ]
Thank you so much rick!
I think that will help a lot.
Author:  Charrlie_S [ Wed Dec 27, 2017 4:46 am ]
Easiest way on the ballast resistor is just tie all four together.
