Thoughts on slant 6 combustion chambers
https://slantsix.org/forum/viewtopic.php?t=6177
Author:  v8440 [ Thu Jul 03, 2003 8:41 am ]
Post subject:  Thoughts on slant 6 combustion chambers
Hi all,
Since I have more experience with the V8's, I don't know much about some specifics of slant engine design. One thing I was wondering about was the combustion chambers, specifically whether they have any quench built in or not. Back in the late 50's when the engines were being designed, I don't think anybody really understood quench and its effects on burn efficiency.
Are slant 6 pistons normally down in the hole at TDC? If they are, perhaps milling the block to bring them up to 0 deck height would bring an increase in power without the detonation problems normally caused by increased compression? I was wondering this because if the piston can be brought to within about .040" of the flat surfaces of the head, you should be able to get good quench, which in turn reduces octane requirements for any given compression ratio. It seems to me that if it's safe to deck the block enough to do this, that would be better than simply milling the head to reach the same compression ratio, which would do little or nothing to bring the piston closer to the flat parts of the head. Am I right, or am I missing something here?
Author:  Doc [ Thu Jul 03, 2003 10:42 am ]
Your thinking is correct, building some quanch into a Slant really helps performance by allowing you to increase compression without detonation.
The issue is the Slants open combustion chamber and the 225's -140+ negitive deck height. In short, it is really hard to get quanch into a SL6.
It can be done but it takes a lot of work. The 170 is a "0 deck height" engine so it is much easer to do on that engine.
Author:  v8440 [ Thu Jul 03, 2003 10:48 am ]
What all has to be done to get it on a 225? I guess decking the block, which then might require shorter pushrods? I wouldn't think you'd want to try to adjust that much using the rockers, as that might screw the valvetrain geometry up. Or, the easy and expensive way would be to get custom pistons made that come up to 0 deck. If you did that, you could also get light pistons, anti-friction coated pistons, etc. I wonder how much that would cost? It just seems to me that having modern quench characteristics in a 225 would make for a much better performing engine with decent mileage.
Author:  Doc [ Thu Jul 03, 2003 11:27 am ]
A quench chamber Slant does run well, here is some info. on one way to get that .040 clearance to the chamber roof.
http://www.slantsix.org/articles/combus ... hamber.htm
Another way I have see this done is thru welding-up the combustion chambers.
Either way makes for a pretty high compression ratio, my current quench chamber SL6 is a 12.5 to 1 motor. :shock:
Author:  Brett K [ Thu Jul 03, 2003 1:32 pm ]
Doc, have you considered angle milling of the head as a method to get quench on one side, but keep enough volume on the other side of the chamber to keep compression reasonable?
Author:  Doc [ Thu Jul 03, 2003 1:45 pm ]
Angle milling works OK but it is hard on the head bolts / studs. (puts side load on them) You can get to a near flat on a 60-67 type head by taking .100 to .125 off the sparkplug side of the head.
The other hassel is that the alturnator mounting needs reworking and the manifold mounting surface should also be angle milled to keep the carb. from tilting.
Author:  v8440 [ Thu Jul 03, 2003 2:24 pm ]
I'm beginning to think that for a motor you plan to use for a long time, the best way to do this would be to get custom pistons made. Might as well get the benefits of a friction-reducing coating and lighter weight as well, assuming you're willing to pay for a balance job. I guess the problem then becomes that of too much compression. Depending on the thickness of various parts of the head, perhaps the combustion chamber could be enlarged with a grinder? In this case, it would be like porting, only you'd be working on the concave surfaces of the chambers, removing metal to increase chamber volume. No, actually the thing to do would be to get dished pistons made with a dish suitable for the compression ratio you want, but with the perimeter of the pistons at 0 deck height so you would have that critical area of close proximity between a flat surface on the piston and a flat surface on the head. Unless I'm missing something, doing that really could allow a custom pistons to solve all problems. Plus, if something ever happened to the head, it could be replaced with any old head without losing a ton of grinding work.
Author:  v8440 [ Thu Jul 03, 2003 2:32 pm ]
Hey Doc, are you Doug Dutra? I noticed that you have "DD" at the end of your posts.
Author:  Doc [ Thu Jul 03, 2003 3:37 pm ]
Uh-oh...you are on to me! Doc. = Doctor Dodge = DD = Doug Dutra
You are also correct on the piston dish solution, I like to use the 2.2 pistons along with the longer 198 connecting rod, that makes for a real light and strong piston with narrow rings and a better rod ratio.
Here is how the dish "lays-out".
http://www.dutra.org/pictures/engine/pa ... layout.jpg
Author:  v8440 [ Thu Jul 03, 2003 3:42 pm ]
Oh man, I'm honored. Your name keeps popping up whenever slant 6 knowledge is discussed. Any guy who has an exhaust modification named after him has earned the title of guru in my book.
On the 2.2 pistons-are they pretty strong? And, how expensive are they? If you can just get a set at std bore or some common oversize and just put them in, that'd be great.
Author:  Doc [ Thu Jul 03, 2003 3:50 pm ]
There is more piston information in this article:
http://www.slantsix.org/articles/stroking/stroking.htm
If you are going to do a "Long Rod" 225 best find a set of 198 connecting rods first, they were only offered 1970 thru 74 (5 years)
Note that a 2.2 bore is Standard at 3.445 so that means a.045 overbore for a SL6.
Author:  v8440 [ Mon Jul 07, 2003 2:30 pm ]
Ok, I've done the math on this combo and it looks good. Theoretically, it 'll leave about .011" of block decking to be done. Two questions:
1. Will using the KB168 dished piston leave enough room for the valves if running a cam with a moderate amount of lift more than stock? (not planning on much extra duration) Or, will valve reliefs still need to be cut?
2. Where does one find a set of 198 rods? 198's aren't exactly falling out of trees.
Author:  Doctor Dodge [ Mon Jul 07, 2003 11:36 pm ]
The dished KB pistons will clear the valves as long as the cam is under .480 lift and has a mild overlap. To get big cams into this combo takes a little "nick" off the edges of the dish, you need to mock-up the combo. and you will find the place that needs a little cut.
As for a souce of 198 rods...they are around. Last I checked there were a couple of sources listed in the site's parts database.
These rods also pop-up on ebay now and then. Also run want ads on all the Mopar sites and start calling engine rebuilders in your local area.
