| Slant six conversion finished-car wont start https://slantsix.org/forum/viewtopic.php?t=6180 |
| Author: | drwheelie [ Thu Jul 03, 2003 1:56 pm ] |
| Post subject: | Slant six conversion finished-car wont start |
Hi Finally found a good usable 2bbl manifold and got everything bolted on. Tried to start the car and no matter how hard I try, it wont turn over. It did catch for just a second but died right away and wont come back to life. Car was running before i started the job Here are some of the things that I think I have been able to rule out. 1. Fuel: turn key and fuel comes out of the fuel line at the carb 2. New plugs properly gapped 3. New plug wires, cap and rotor: double checked vs manual to ensure all wires are hooked up correctly 4. Timing and valves set several months prior to this service, distributor firmly held down so timing should be on 5. Holley 2280 carb totally rebuilt by excellent local shop. Carb was supposedly bench tested. 6. Throttle cable and return spring hooked up correctly 7. Tested a few plugs to see if they arced to the block when car cranks, they do so I am assuming I have spark 8. Charged battery. Fan turns when turning the key so I am assuming starter works fine. 9. choke is unhooked, it is hot here so it shouldnt matter Here are some things that I dont think will matter but may make a difference 1. Exhaust manifold not hooked up to anything at flange. My friends muffler shop is about 1 mile from my house. I figured once I got it to start I would just drive it down to the shop for the 2 1/4 inch exhaust so wy bother hooking exh manifold up. Will this keep car from starting? 2. Kickdown linkage not set up yet. I am working on the car in front of my house with the car on the street. I was planning on driving it from the muffler shop to my friends driveway so I can raise the car and swap out the kickdown. Dont think this will keep it from starting, will it? 3. Charcoal canister not hooked up to anything. The carb I have does not have the nipple for the carb bowl line that comes off the canister. I vaccume capped it. 4. Unsure where to hook up the vacuume advance on the carb. I am unable to find a diagram of how to hook up the vaccume lines to the holley 2280. None of my manuals cover this carb. Only the bbd and the holley 2245. I have tried to extrapolate from these drawings but maybe I am off? Still, car does not need to have vacuume advance to start does it? My guess for the culprit is the carb but I will say that when you move the throttle, you can see gas shooting out of the jets on the top. I have been able to get it to start very very briefly and then it dies. It took a lot of cranking and mashing on the gas just to get the thing to start. My next step is to buy a rebuild carter bbd from napa and give it a try. I just hate to spend the money on this only to find out this isnt the issue So, any experts out there want to take a guess at what is going on? Thanks in advance Dr wheelie |
| Author: | DusterIdiot [ Thu Jul 03, 2003 2:34 pm ] |
| Post subject: | Hmmmm.... |
It should run even without the dist adv. hooked up, but make sure you have all the vaccuum ports on the manifold, and the carb 'plugged'. (If you drive it without dist. adv, don't expect anything really exciting for acceleration...) Have you poured a slosh of gas into the carb bore to see if it'll 'fire' you might have the carb lean, or the choke isn't properly set. sounds like you have fire but nothing is getting lit... -d.Idiot |
| Author: | drwheelie [ Thu Jul 03, 2003 3:41 pm ] |
Oh yeah poured plenty of gas into the bowl. I left it overnight, cleaned off all the plugs, they were wet from flooding and came out today and tried again. It started first thing but died after about 2 seconds. Then I just cranked and cranked it until it finally started again, ran for 5 seconds or so and then died. At that point I walked off for awhile to make sure the battery wasnt drained and now here I sit scratching my head. I am sure it is a carb thing. I am contemplating just buying a rebuilt bbd from napa and using it instead. None of my manuals have any info on the 2280. -DW |
| Author: | GuyLR [ Thu Jul 03, 2003 3:45 pm ] |
Ditto on plugging the vacuum leaks. I run a 2280 on my M1 two barrel intake and it works fine except for a little hard starting when hot due to modern fuel. Mine has a small distributor vac nipple on the right side of the base just in front of the throttle shaft. It point to the distributor so its hard to miss. |
| Author: | drwheelie [ Thu Jul 03, 2003 4:22 pm ] |
Got it to fire. I moved a few vacuume lines around and capped a few things. I also found I had some corrosion on my coil lead and a few of my distributor wire ends in the cap. They are only 6 months old but I also just replaced the negative battery terminal because I noticed that I had a ground problem. I think that may have caused the corrosion. Now I have to dial the 2280 in and get er to the muffler shop. Rats, I have to wait till Monday because of the holiday -DW |
