I would have no trouble with that behavior in my car, assuming you are holding pressure in the cooling system and preferably have some (>20%) coolant in the system. Welcome to the site! Where are you located?
located in the primordial swamps of SETX
we'll have 100 degree heat index days until about October
I guess my more specific question is: "Is it an accurate way to determine engine temp by putting a baking thermometer into the coolant at the top of the radiator when the engine is at max operating temp?".
Looks like my aftermarket gauge is reading too high (its sending unit is mounted in the lower side of the block by the oil pressure/oil filter).
Factory gauge looks ok, 185 coolant temp at the top of the radiator.
