It is currently Thu Jul 16, 2026 10:07 pm
PostPosted: Mon Jul 07, 2003 1:45 pm
I was about to replace my valvecover gasket, and thought about buying a Clifford aluminum cover but I don't think I want to spend $150 on a valve cover.
So I got creative and thought, I bet I could get the local plastic shop to bend me a cover and drill the holes for probably less then $150. Do you think lexan/plexi/etc would hold up to the oil and temperatures?
I am not doing this exclusively for having a clear cover to see the valvetrain, I just want a sturdier cover and figured, hey why not a clear cover would be neat if I could get one at the same time. Sure would be unique...
PostPosted: Tue Jul 08, 2003 7:57 am
Once oil gets on them from splash, you can't see much.
Cecil
PostPosted: Tue Jul 08, 2003 10:36 am
If you want a cool valve cover, just do what I did and paint your valve cover with black wrinkle paint from Krylon! All it costs is a can of paint and an afternoon for prep work and drying time. 8)
PostPosted: Tue Jul 08, 2003 2:35 pm
Hmm... yea forget it I'll just straighten my cover as much as I can when I take it off and spend the money elsewhere.
A quick paint touchup might be in order.. the degreaser I used the other day "Oil Eater" brand, full strength as it said on the bottle, seemed to have a bleeching action on the paint, its still on there but almost white where the spray got on the cover.
PostPosted: Tue Jul 08, 2003 3:49 pm
At one time Doug had found someone who could make clear valve covers. IIRC, there was not enough interest to make the minimum number required for a production run. :shock:
