It is currently Mon Nov 16, 2026 8:21 am
PostPosted: Wed Jan 17, 2018 12:48 pm
I will be starting to open up the RedLine manifold I have to get a little larger port size. Can anyone recommend a decent place to get aluminum burrs. As always price is a factor. Plus I'm not going to use them much. It may be a one time deal.
Thanks
PostPosted: Wed Jan 17, 2018 2:57 pm
Online
Maybe try these:
https://www.amazon.com/TEMO-Aluminum-CA ... B00385NKW4
I just did a web search for carbide aluminum cutter.
I believe you can also try a standard carbide burr /rotary file with cutting fluid. I am not certain on either but might give you a starting point.
PostPosted: Wed Jan 17, 2018 3:52 pm
Yes that is one I was looking at too. Probably for all the more I am doing I can try the ones I have. I may just buy one or two different shapes and call it a day. Thanks!
Rick
PostPosted: Wed Jan 17, 2018 6:21 pm
Yes, in fact years ago Doc told me use wax with the burr to keep the aluminum from taffying
and fouling the burr. It's a slow process but does work... I think if I needed to hog out a fair
amount of material I'd look for a burr with a coarser/ aggressive set of teeth than what the typical
burr has on it...
PostPosted: Wed Jan 17, 2018 9:52 pm
Set of Harbor Freight cutters and a couple cans of WD-40 and you're golden.
PostPosted: Thu Jan 18, 2018 3:00 am
Thanks guys!
PostPosted: Thu Jan 18, 2018 5:31 am
SSRN National Champion
Another suggestion might be Eastwood. I have used them and they worked very well.
