It is currently Tue Nov 24, 2026 3:13 am
PostPosted: Tue Jun 24, 2003 7:12 am
ok guys are there any tricks to getting lifters out that don't want to come out,I'm using a magnet to lift them out ,so far, 6 have come out ,the rest wont,will the tool thats meant for this job work or will it slip off too,the magnet will hold 30 pounds,if I don't have to take the head of it would be great,but if i have to I guesse I have to :x .well tell me what you think,thanks,,,speedfreak.
2001dodge cargo van,,88jeep4.0,,81 dodge pickup,,73 dart sport 318(360soon)
PostPosted: Tue Jun 24, 2003 8:39 am
Never tryed this with the head on. I have used a long needle nose pliers to grab the edge of the lifter, and pull it up.
PostPosted: Tue Jun 24, 2003 9:08 am
Push the lifters down on the cam with a screw driver. Pull the spark plugs and spin the engine over with the starter. Should pop them right out
Gilly
1960 Dodge Pioneer
"Long Rod" /6, A833 Pistol grip Hurst
8 3/4" w/Suregrip and 3:91's
Still have more parts in boxes than on the car....
PostPosted: Tue Jun 24, 2003 1:14 pm
Put the magnet on the edge of the lifter, not the center, and slowly pull up and move the magnet in a slow circular motion so the lifter turns in its bore. This helps use the oil thats still there to let the lifters slip out.
You don't have to take the head off. Putting them in with the head on is another story! I had a very... not so fun time trying to get them positioned and in their bores with the head on, with some cursing they finally went. I just hope I didn't ding them up too bad...
PostPosted: Wed Jun 25, 2003 9:40 am
thanks for the replies,I'll try the spining the motor over trick&needle nose plyers,I had no problem getting the new ones back in,using the magnet,and a push rod to hold it in place so I can get the magnet back out ,thanks,,,speedfreak.
PostPosted: Wed Jun 25, 2003 11:34 am
On a high milage engine you can get a raised ring of "crud" (coked oil) on the ends of the lifters.
This is due to the fact that the end of the lifter hanges out between the lifter bore and cam, the lifter body is not protected / cleaned by motion in the lifter bore.
You may have to spray some carb cleaner down around the lifters and work them up and down until you knock the crud away.
PostPosted: Fri Jul 04, 2003 4:42 am
thanks for the replies guys,the lifters are out ,I had to take the head off and use a needle noze plyers and carb&choke cleaner to get them out,the super six is running good,thanks again,,,speedfreak,,,,,,HAPPY and SAFE 4 OF JULLY. :P
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 9 guests
