| Oregon Cam 2106R Spec Sheet. https://slantsix.org/forum/viewtopic.php?t=61877 |
| Author: | emsvitil [ Sun Jan 28, 2018 1:24 am ] |
| Post subject: | Oregon Cam 2106R Spec Sheet. |
Thought I had it. Does anyone have the Oregon Cam 2106R spec sheet you get from them when you get their cam? Thanks |
| Author: | drgonzo [ Mon Jan 29, 2018 10:35 am ] |
| Post subject: | Re: Oregon Cam 2106R Spec Sheet. |
I too have wondered about this cam grind and maybe a couple more I have seen referenced in posts that do not appear in the cam lobe sheets listed here in the forum. I have to assume these are grinds on file at OCG but not listed on their lobe reference sheet. Still would be nice to see the specs on some of them. |
| Author: | mopar_nocar [ Mon Jan 29, 2018 6:16 pm ] |
Just sent my core to them. Will post my card when it comes back if no one beats me to it. sb |
| Author: | drgonzo [ Mon Jan 29, 2018 6:46 pm ] |
Quote: Just sent my core to them. Will post my card when it comes back if no one beats me to it.
'preciate it.
sb |
| Author: | drgonzo [ Tue Jan 30, 2018 1:22 pm ] |
Found this on another site: #2106 210/214 @ .050”, 254/254 adv, .434”/.444” lift, 108 sep I have to assume the 'R' means reverse the two lobe positions. Similar to the RV10. |
| Author: | mopar_nocar [ Wed Feb 14, 2018 5:58 pm ] |
Grind # 2106R Lobe separation: 108 intake centerline: 104 Exh centerline: 112 Intake opens 3 BTDC closes 31 ABDC Exhaust opens 37 BBDC closes -7ATDC Dur 214/210 @ .050 Lift 444/434 Valve clearance: Int .015 Exh .015 -4* overlap @ .050" That's all of them that are pertinent, I think. sb |
| Author: | emsvitil [ Wed Feb 14, 2018 7:05 pm ] |
Looking for this: https://onedrive.live.com/?cid=935E825B ... 39&o=OneUp for the 2106R |
| Author: | SlantSixDan [ Thu Feb 15, 2018 10:17 am ] |
Maybe give Oregon Cam Grinding a call and see if they'll send you it? |
| Author: | mopar_nocar [ Thu Feb 15, 2018 5:01 pm ] |
Quote: Maybe give Oregon Cam Grinding a call and see if they'll send you it?
I just posted everything from mine that I got in the mail yesterday. Quote: Looking for this: for the 2106R What else do you need from it? PM your address, and I will mail you a copy of mine, if you like. sb |
| Author: | coconuteater64 [ Wed Jun 19, 2019 8:35 am ] |
Just a little off topic, but what kind of idle does this cam have? |
| Author: | Dart270 [ Wed Jun 19, 2019 11:18 am ] |
Stock idle. Just a tiny bump up from stock 71-up cam. Lou |
| Author: | coconuteater64 [ Wed Jun 19, 2019 12:28 pm ] |
Quote: Stock idle. Just a tiny bump up from stock 71-up cam.
Thanks! This is going in a pickup so I didn't really need it to lope. I just want it to pull a couple kayaks and a teardrop camper, and any bump over stock is welcome! Bonus points for good vacuum.
Lou |
