It is currently Tue Nov 24, 2026 9:48 am
 Post subject: Major prob i need help
PostPosted: Sun Jul 06, 2003 7:09 pm
i have a 70 dodge dart custom......i just replaced the fuel pump and the card......at first when the car was started it would run for a bit then die...i looked at the fuel filter and it was dry...i let it sit for about an hr and the filter was half full.......we replaced all of the fuel line from the tank up to the filter / the filter to the pump and the pump to the carb....then it ran ok...now it is cutting out again....when you drive it it stays running while idleing but when you put it in gear it will cut out every now and then...now when i drive it down the road it dies then it will start right back up then after awhile again it dies...after like 1/2 mile or so....any ideas what it could be? b/c all of the fule items are new the line and the pump and the carb....please if u know what is wrong tell me or e-mail me at grimsk8ter69@aol.com
dartman69
PostPosted: Sun Jul 06, 2003 10:26 pm
I'm not sure but ...
I had a fuel problem. I got a new fuel pump and was still having a problem. I figured out that I got a different pump. The lever was more straight than the original. I got the second one at Pep Boys and noticed the difference in the arm. Not sure if that helps. :?
