| 66 valiant Odometer is functioning, but speedo is not? https://slantsix.org/forum/viewtopic.php?t=6191 |
| Author: | newpoppop [ Sat Jul 05, 2003 6:36 am ] |
| Post subject: | 66 valiant Odometer is functioning, but speedo is not? |
do I need a new speedo? I replaced the cable that the guy that I bought it from threw in, but the speedo does not register... any help wouod be appreciated... thanks Chris |
| Author: | 64 Convert [ Sat Jul 05, 2003 11:42 am ] |
It sounds like you have a bad speedometer...probably a stripped gear in the head or a broken shaft. They can be repaired, but you can probably find a working unit for much less than a repair would cost. |
| Author: | newpoppop [ Sat Jul 05, 2003 12:46 pm ] |
is it something I could try to fix myself? I am going to do the voltage limiter for the other gauges... thanks Chris |
