| Major prob i need help https://slantsix.org/forum/viewtopic.php?t=6200 |
| Author: | dartman69 [ Sun Jul 06, 2003 7:09 pm ] |
| Post subject: | Major prob i need help |
i have a 70 dodge dart custom......i just replaced the fuel pump and the card......at first when the car was started it would run for a bit then die...i looked at the fuel filter and it was dry...i let it sit for about an hr and the filter was half full.......we replaced all of the fuel line from the tank up to the filter / the filter to the pump and the pump to the carb....then it ran ok...now it is cutting out again....when you drive it it stays running while idleing but when you put it in gear it will cut out every now and then...now when i drive it down the road it dies then it will start right back up then after awhile again it dies...after like 1/2 mile or so....any ideas what it could be? b/c all of the fule items are new the line and the pump and the carb....please if u know what is wrong tell me or e-mail me at grimsk8ter69@aol.com dartman69 |
| Author: | Pierre [ Sun Jul 06, 2003 8:28 pm ] |
When you replaced the carb, did you do any adjusting? Sounds like the idle may be a bit low. Also check your timing, distributor, wires, cap etc. |
| Author: | 87Slant_sickness [ Sun Jul 06, 2003 9:00 pm ] |
sounds to me like the pickup in the tank could be clogged, try bowing some compressed air throught the lines, or drop the tank and clean the filter out... Justin |
| Author: | blacknails [ Mon Jul 14, 2003 2:58 pm ] |
| Post subject: | sending unit |
I had same symptons with my Dart. Suspecting the sending unit was clogged I removed hose from the tank side of the fuel pump, and blew air back into the tank. This action blew the sock off of the sending unit and fuel flowed great. Car ran like a dream, until the next day. The stirring of the tank with compressed air caused an inordinate amount of tank varnish to disolve and flow into the engine. My expensive fuel filter did not help stop the liqufied gum. Next morning I tried to crank the car, and bent all of the push rods. The valves were stuck so tightly that I had to get a new head job, two days after installing the newly rebuilt engine. I have since installed a new sending unit in a NEW fuel tank. (the people at Krammer are really helpful, with locating fuel tanks and sending units.) Gasoline flows fine now. In summary I would not blow air back into the tank if there was a possibility the tank was dirty. Why does education have to cost so much? |
| Author: | 64 Convert [ Mon Jul 14, 2003 3:18 pm ] |
Did you replace the gas cap? If you installed the wrong one, air will not enter the tank to replace the burnt fuel. |
| Author: | Jopapa [ Mon Jul 14, 2003 4:03 pm ] |
Quote: sounds to me like the pickup in the tank could be clogged, try bowing some compressed air throught the lines, or drop the tank and clean the filter out...
How easy/difficult is it to drop the tank and get to the sending unit? I need to replace the wire to the fuel gauge anyway since I suspect there's a fray or break somewhere towards the tank, so I may as well do the full monty while I'm in thereJustin and what's a good solvent to clean any crud out of a tank that old? |
