| Stuck cylinder head won't come off https://slantsix.org/forum/viewtopic.php?t=6202 |
| Author: | VE Safari [ Sun Jul 06, 2003 9:02 pm ] |
| Post subject: | Stuck cylinder head won't come off |
Hey, I need some help removing get the the cylinder head off my slant parts car. The engine hasn't run since Christmas. Coolant is drained but there is oil in the motor. All head bolts removed. Rocker shaft, alternator bracket and manifolds have also been removed. The head won't budge... I wedged a bit of 4x2 under the front of the head and jacked the car up off the ground. Still the head stayed in place. I remounted the manifolds and took a 6' length of 4x2, wedged it between the down pipe and inner guard and tried to lever the head off. The 4x2 snapped... This is getting silly. Any ideas or suggestions will be gratefully received. thanks, Eyman |
| Author: | Eric W [ Sun Jul 06, 2003 10:36 pm ] |
Hmmm, never had this problem before. Maybe put some plugs in, disconnect the ignition and crank the engine over. The compression might knock it loose.... Edit: You might want to reinstall the rocker arms.... |
| Author: | Pierre [ Sun Jul 06, 2003 10:36 pm ] |
I had some issues gettin my head off too but not as severe it appears as yours. I think I either wedged something between the head and waterpump and pried up, or put something in the water outlet and pried there. Also don't forget to remove the rubber hose between the head and waterpump. It might help to heat up the head/block a little with a torch or heatgun... run either up close to the headgasket around the engine, that might soften the gasket up a bit. |
| Author: | VE Safari [ Mon Jul 07, 2003 12:15 am ] |
| Post subject: | Head is off |
I finally got the head off by using a 4' length of 1" water pipe and inserting into the #1 inlet port and prying the head off. The pipe material is softer than that of the head itself so I don't think it did any damage. If I ever find out what joining compound was used on the head gasket I'll build a house out - it's strong stuff! Thanks for the suggestions. Eyman |
| Author: | Pierre [ Mon Jul 07, 2003 12:27 am ] |
Who knows, that may of been the first time the head ever came off that engine. |
