| rocker arm shaft question https://slantsix.org/forum/viewtopic.php?t=62090 |
| Author: | fireguyfire [ Fri Mar 16, 2018 5:04 pm ] |
| Post subject: | rocker arm shaft question |
Getting my 1970 slant 6 back together today and got the head on. Finally decided to clean up the rocker shaft and arms, which I did. there are the larger mounting bolt holes in the rocker shaft , as well as the smaller oiling holes for each rocker arm on the shaft. I realized I now don't know which way to orientate the rocker shaft with the arms on it; small oiling holes facing up, or small oiling holes facing down towards the bottom of the engine. Can anyone help me out with this? |
| Author: | Reed [ Fri Mar 16, 2018 5:24 pm ] |
| Post subject: | Re: rocker arm shaft question |
Yes! The information you want is HERE! Click on the red text. |
