It is currently Mon Dec 29, 2025 4:10 am
PostPosted: Fri Mar 16, 2018 5:04 pm
Car Model: 1970 D100
Getting my 1970 slant 6 back together today and got the head on. Finally decided to clean up the rocker shaft and arms, which I did.
there are the larger mounting bolt holes in the rocker shaft , as well as the smaller oiling holes for each rocker arm on the shaft.
I realized I now don't know which way to orientate the rocker shaft with the arms on it; small oiling holes facing up, or small oiling holes facing down towards the bottom of the engine.
Can anyone help me out with this?
PostPosted: Fri Mar 16, 2018 5:24 pm
Yes! The information you want is HERE! Click on the red text.
Users browsing this forum: Ahrefs [Bot] and 1 guest
