| a903 is it dead? https://slantsix.org/forum/viewtopic.php?t=62105 |
| Author: | Adams_65_valiants [ Mon Mar 19, 2018 3:21 pm ] |
| Post subject: | a903 is it dead? |
So this is the second time I've had to pull this transmission in 14 years (not bad). First time was for input bearing, and threw a clutch at it while I had it out. The snap ring on the input shaft broke in half and couldn't find the right part easily so I made it work with two narrower snap rings. Well I got the dreaded grinding again so I pulled the trans and found the snap ring on the input shaft had snapped again (both of them) It also tore up the washer that goes behind it, I may be able to make the washer work again, but the snap ring seems to be impossible to find! I was also looking into just rebuilding this trans while I have it out this time, but cannot seem to find a reliable source for the rebuild kits. At least havent found one that has actually called me back. Is this just a completely dead line of transmission? I really like the novelty of the three on the tree and would like to fix what I have. I've had this car since I was 17 and really want to get it back to it's former glory! |
| Author: | DadTruck [ Mon Mar 19, 2018 5:43 pm ] |
| Post subject: | Re: a903 is it dead? |
this would be a a real long shot, but try calling Brewer's and/or Jamie Passion both of those shops specalize in A833's but they are both great to work with and they may have a lead on mopar 3 speed tranny parts. another option is to put an ad up:on .org, on FABO, on Moparts,,, looking for a A903, there is probably someone swapping one out for a 4speed.... |
| Author: | Greg Ondayko [ Fri Apr 27, 2018 8:51 am ] |
Maybe this can help you out. http://www.makcotransmissionparts.com/MTP-A903.html Greg |
| Author: | sandy in BC [ Fri Apr 27, 2018 9:33 am ] |
I have a 903 you can have. How close are you to Colville? |
| Author: | dirtyd100 [ Mon Apr 30, 2018 11:34 am ] |
Just pulled a good A903 out of my truck that I would get rid of cheap if you are interested. Worked fine except the shifter was junk, just wanted another gear so I am swapping in a 4 speed. PM me if you are interested. |
| Author: | Greg Ondayko [ Wed May 02, 2018 6:07 am ] |
903 from a truck might not fit an A Body due to tailshaft / output length. If poster is okay with swapping output shafts and tail housings then maybe it's an option. Greg |
