It is currently Tue Jun 23, 2026 6:13 am
PostPosted: Tue Mar 20, 2018 12:40 pm
I'm disassembling the engine, can't get oil pickup tube to turn, and suspect there is a bit of loctite involved. I'm afraid to get too aggressive and bend it.
PostPosted: Tue Mar 20, 2018 2:12 pm
Towel + vise grips/channel locks.
Wrap pickup tube in towel as close to black as possible, use pliers to get tube turning.
PostPosted: Tue Mar 20, 2018 2:45 pm
Use the hot wrench (torch) on the block where it screws in.
PostPosted: Tue Mar 20, 2018 3:10 pm
Use pipe wrench.
A bit of torch can help too.
PostPosted: Wed Mar 21, 2018 4:18 pm
If it breaks, you can grind a line inside the stub and pry out the remains. Done that... NPT will thread in and you can weld or maybe thread a piece onto the old pickup.
PostPosted: Thu Mar 22, 2018 4:45 am
Pickup unthreaded with a little heat from yellow torch and small pipe wrench. It let go with a snap, then turned easily.
PostPosted: Thu Mar 22, 2018 3:05 pm
Loctite type products will melt at between 200-450 F, depending on which formulation, the red type being the 450 degree range. If you're afraid of using a torch for fear of getting it too hot, you can use a heat gun, but it takes more time (a lot of metal to heat). Most of us are impatient in such circumstances and reach for the torch. If your work area is otherwise clean, a clear sign is that the loctite will begin to smoke as you near the melting temperature (if there's oil residue/paint, those will smoke as well). If you have a laser IR thermometer you can monitor the area easily and watch the temperature.
b
https://tinyurl.com/yynpj4v2
PostPosted: Thu Mar 22, 2018 3:07 pm
Glad you got it loose!
Users browsing this forum: Andrew Shank, Bing [Bot], Google [Bot] and 3 guests
