It is currently Wed Nov 25, 2026 7:40 am
PostPosted: Fri Jul 11, 2003 6:42 pm
Hi
Justy trying to get the super six dialed in correctly.
I am new to fiddling with carbs so I wanted to ask some advice of some more experienced than I.
I have the idle dialed in so the car idles nicely in park but when I am sitting at a light with the car in drive, it wants to slowly move forward (i.e., it is still getting enough gas to make it want to go).
I have played with the full range of travel on the curb idle adjust screw but it makes no real difference, the car still wants to move forward in drive with the throttle closed. In fact it doesnt seem like moving the fast idle screw does anything related to the issue I am having.
So I am not sure what is going on. Its dark already but next I want to try messing with the mixture screws at the carb base.
Any advice on how to approach this?
I am guessing it is just an issue of getting the screws at the base of the carb set right relative to the idle adjustment.
I havent even started to mess with the fast idle yet because I need to get this issue fixed.
Thanks
DW
Dr Wheelie
PostPosted: Fri Jul 11, 2003 8:25 pm
First thing, make sure the throttle cable is not too tight. It might be holding the carb open a little bit. If that is the case , the idle speed adjustment screw will not have much effect.
PostPosted: Fri Jul 11, 2003 11:06 pm
The kick-down linkage can also hold the throttle open.
A worn throttle shaft or any small vacuum leak will make it hard to idle down the carb.
I have seen carb. butterflys that were not centered well cause a fast idle problem, they would not fully close-off the airflow.
PostPosted: Sat Jul 12, 2003 8:26 am
I diconnected the throttle cable, put er in drive and she still rolls forward-so its not the throttle cable
I disconnected the kickdown linkage spring and put er in drive and she still rolled forward so it is not the kickdown linkage.
I tried fiddling with the mixture screws and the curb idle adjust for a good 30 minutes and it seems very easy to get the car to idle nicely, even with the curb idle screw set so it is not contacting anything but still cant get rid of the fact that the car rolls forward in park with no pressure on the gas.
A reply to my earlier post mentioned the possibility of an incorrectly set butterfly valve. I had the carb rebuilt by a specialty shop here in town and it seems to be set spot on, the car runs very nicely throught the range of the throttle. I dont know what the position of the butterfly should be but I havent hooked up the choke yet and the butterfly is straight up and down vertically (no restriction of airflow) as the car sits at idle when it is warmed up.
So, based on the responses I recieved for my earlier post on this subject, the only thing I cant rule out is the butterfly, what is it supposed to look like? Any other ideas?
Advice is appreciated as always
-DW
Dr Wheelie
Users browsing this forum: Google [Bot], Rick Covalt and 6 guests
