It is currently Fri Nov 20, 2026 9:55 am
PostPosted: Sun Apr 15, 2018 1:18 pm
Car Model: 1975 Plymouth Duster
What the title says. After traveling over 30mph for a minute or so, the engine suddenly wants to die when I hit the brakes. I checked for vacuum leaks with carb cleaner, and there aren't any (although someone cut out a lot of the vacuum lines in the past). Sometimes when the engine dies after this it really doesn't want to start back up, and I have to feather the pedal just to keep it running. It has power brakes, with one vacuum line leading into the #6 intake tube. Kinda need this car to be reliable as my daily is now having a lot of issues.
PostPosted: Sun Apr 15, 2018 3:44 pm
I would suspect a leak in the brake booster just based on the info you provided, but I really have no experience with power brakes on these cars.
What's the year and model?
Escape Velocity Racing
PostPosted: Sun Apr 15, 2018 4:27 pm
1975 Duster.
PostPosted: Mon Apr 16, 2018 5:28 am
If no power brakes:
Braking also causes fuel to slosh forward in fuel bowl. If fuel pump is under performing, and or float incorrectly set or fuel logged, result would be low fuel level in bowl, slosh action could leave jet high and dry momentarily.
