| Trans adapter plate ID please https://slantsix.org/forum/viewtopic.php?t=62210 |
| Author: | paintman [ Tue Apr 17, 2018 4:28 am ] |
| Post subject: | Trans adapter plate ID please |
A guy over on the HAMB wants to know what trans plate this is. Thanks guys! part #1612346 ![]()
| Author: | Charrlie_S [ Tue Apr 17, 2018 10:48 am ] |
| Post subject: | Re: Trans adapter plate ID please |
Looks like the adapter to install a small block 727 trans to the slant six engine. However the crank adapter is missing. |
| Author: | Rick Covalt [ Tue Apr 17, 2018 1:33 pm ] |
No Charlie it is a garage door adapter and it has the key hole to prove it. |
| Author: | Charrlie_S [ Tue Apr 17, 2018 1:58 pm ] |
Quote: No Charlie it is a garage door adapter and it has the key hole to prove it.
Dang, you're right. How did I miss that?
| Author: | SlantSixDan [ Tue Apr 17, 2018 3:00 pm ] |
That ain't no grudge door adaptor, it's a meatloaf adaptor! |
| Author: | and739 [ Tue Apr 17, 2018 5:49 pm ] |
Two Out of Three Ain't Bad. |
| Author: | Dart270 [ Wed Apr 18, 2018 3:22 am ] |
That does not look anything like the 727 to Slant 6 adapter plate I have. I would match it up to a Slant 6 block and an A-engine trans to see if it fits before I were to plan anything. Lou |
| Author: | Charrlie_S [ Wed Apr 18, 2018 4:04 am ] |
Lou could be right. I was going by the starter location, and the two bolt holes that could be for the bellhousing to engine brace. I couldn't trace the part number. I know a swap meet Mopar vender that had a adapter, that I thought was for the slant,but was for a early V-8, can't remember which. I will try to call him, and ask. |
| Author: | SlantSixDan [ Wed Apr 18, 2018 5:31 am ] |
Starter bolt pattern looks much more Ford than Mopar to me, and even if it is a Chrysler item, that casting number is way too low to have anything to do with Slant-6s. |
| Author: | Charrlie_S [ Wed Apr 18, 2018 6:13 am ] |
I have been told the early Hemi (1950's) used this adapter, to use a torqueflite, or powerflite. Still have not found this part number, but 1612344 is for 55-56 some others, 241-330-331-354 hemi, and some non 318 poly engines. |
| Author: | SlantSixDan [ Wed Apr 18, 2018 8:42 am ] |
That sings, Charlie—starter pattern could be pre-Slant Chrysler. |
| Author: | sandy in BC [ Wed Apr 18, 2018 9:29 am ] |
That may be a flathead piece. 251 Desoto to Simplimatic (or Problematic ) I might have one..... |
| Author: | Joshie225 [ Wed Apr 18, 2018 10:23 am ] |
My money is on the application being Fluid Drive behind a flathead. |
