Timing chain sprocket install
https://slantsix.org/forum/viewtopic.php?t=62229
Page 1 of 2
Author:  Wesola78 [ Sat Apr 21, 2018 9:12 am ]
Post subject:  Timing chain sprocket install
So, is there a special tool for installing the sprocket that goes on the crankshaft?
Or, does it just slide on, with a little "persuasion"?
Thanks!
Author:  DusterIdiot [ Sat Apr 21, 2018 9:29 am ]
Post subject:  D
D
Author:  Wesola78 [ Sat Apr 21, 2018 10:15 am ]
Post subject:  Re: Timing chain sprocket install
Okay, thanks!
So, put the crank sprocket on first, then the timing chain and other sprocket?
Author:  sandy in BC [ Sat Apr 21, 2018 10:22 am ]
crank first
.....then you have to get the cam timing right.
lazy way:
roll the crank to #1 TDC
roll cam to close intake and exhaust valves on #1
Bolt on cam gear and chain without disturbing cam or crank.
Using degree wheel ensure cam timing is correct.
Author:  Wesola78 [ Sat Apr 21, 2018 10:47 am ]
Ugh, can't get it on all the way.
I'll try again after work...
Author:  Charrlie_S [ Sat Apr 21, 2018 11:05 am ]
You can use a piece of pipe, that slides over the crank snout. Big washer/something, and the crank bolt, and push the sprocket on. I actually have an old crank pulley hub, that is honed out to a slip fit. I can use that to press the sprocket, and also use to mount the degree wheel. Key way keeps it from slipping, but if I have to remove the degree wheel for any reason, it just slides off and back on in the same position.
Author:  Wesola78 [ Sat Apr 21, 2018 11:09 am ]
Thanks Charrlie!
Author:  Wesola78 [ Sun Apr 22, 2018 12:41 pm ]
Well, the bolt will not thread into the crankshaft.
The sprocket is not on far enough, and now I can't remove it.
Any suggestions?
Author:  DusterIdiot [ Sun Apr 22, 2018 3:44 pm ]
Post subject:  D
D
Author:  Charrlie_S [ Sun Apr 22, 2018 4:36 pm ]
Why won't the bolt screw into the crank? Are the threads messed up? Need to fix it. Otherwise, how are you going install the crank damper?
Author:  Wesola78 [ Sun Apr 22, 2018 5:06 pm ]
Ok, removed the pulley using a puller, so I'm back where I started.
Good question Charrlie, not sure. I think its the threads inside the crankshaft.
So, should I chase the threads?
Thanks for the replies fellas!
Author:  DusterIdiot [ Sun Apr 22, 2018 7:27 pm ]
Post subject:  D
D
Author:  Greg Ondayko [ Mon Apr 23, 2018 10:05 am ]
I am assuming the crank is in the car / engine?
There is a Harmonic Dampener install tool that I like to use for this situation..
Works with dampeners and Lower Timing gears - Some times the lower gear needs to be sanded a bit to get the proper press fit.
https://www.summitracing.com/parts/sum-g1023-1
the one I have is not available but this does similar.
Heating can help as other posters had mentioned.
Author:  halfafish [ Mon Apr 23, 2018 8:26 pm ]
Wes,
I'm getting ready to do a timing chain on my 82 D150. I knew my crank bolt would not be long enough to reinstall the harmonic balancer, and anyway I didn't like the idea of using a bolt with the crank female threads providing the the pulling power to install the balancer. So I bought a big piece of 3/4-16 allthread and cut it into 6" chunks. Now I can thread the all-thread fully into the the crank with a double-nut to anchor the rear end and keep it from rotating. Then, using one additional nut with a washer to drive on the balancer I'm home free. This should work fine to install both your gear and balancer. I have several more of these I will not need so if you want one, PM me to discuss. I'd sell one for peanuts plus shipping.
Author:  halfafish [ Mon Apr 23, 2018 8:39 pm ]
Oops. Also forgot to mention I have a flat bottom 3/4-16 tap I'd be happy to loan you to chase your threads.
Page 1 of 2 All times are UTC-07:00
