| Interesting Collision Damage to K-frame https://slantsix.org/forum/viewtopic.php?t=62270 |
| Author: | SpaceFrank [ Sat Apr 28, 2018 7:14 pm ] |
| Post subject: | Interesting Collision Damage to K-frame |
I was up under the '64 Valiant wagon today, deciding what needs replacing in the front suspension. Turns out, surprisingly little for now; a couple deteriorated tie rod end boots, but everything feels solid. The car had been sitting for about 20 years when I bought it, and it looks like many of the common wear items had been replaced at some point. I did notice something I'd never noticed before, though. Looks like a previous owner had a little adventure with a high curb, or something. ![]() That's not how this brace was originally shaped... ![]() The K-frame is cracked next to where the passenger side strut rod goes through. How hard did they have to hit to do that? ![]() My plan is to remove the bushing, clean up the damaged area, get it good and hot with a torch, hammer the damaged area flat, drill-stop the cracks, and weld the piss out of it. I don't see any other damage, which is nice if a little surprising. I haven't driven the car more than about 25 mph, but I didn't notice any terrible handling characteristics at least. |
| Author: | sandy in BC [ Sat Apr 28, 2018 8:16 pm ] |
| Post subject: | Re: Interesting Collision Damage to K-frame |
Not uncommon.....you have a good plan. |
| Author: | Dart270 [ Sun Apr 29, 2018 3:51 am ] |
Yep, good to fix before it gets worse! My 68 Dart front brace looked like that for about 30 yrs. I made a new one recently out of 3/4" round tubing, flattened and welded shut on either end to bolt on. Lou |
| Author: | wjajr [ Sun Apr 29, 2018 6:15 am ] |
That crack could be a relic resulting from worn or age rotted bushing allowing radius rod to pound forward and backward while under way. Those old stile bushings looked like little rubber cones with much less surface area contacting K frame. Your plan to repair will work just fine, and the so called H. D (B body) bushings will distribute the forces much better. |
