Tubes in slicks...
https://slantsix.org/forum/viewtopic.php?t=62298
Page 1 of 1
Author:  Rob Simmons [ Fri May 04, 2018 6:02 am ]
Post subject:  Tubes in slicks...
I'm sure neither the Challenger or Duster have tubes currently... Ordering the M/T slicks for the Duster (yes, my first time ever buying slicks :roll: ) and Summit sez I gotta have 'em!
Y'all runnin' tubes in yer slicks...?
Author:  Greg Ondayko [ Fri May 04, 2018 8:49 am ]
Post subject:  Re: Tubes in slicks...
You can run them. I don't.
Pressures may be more consistent, at the expense of more rotating weight.
Author:  Badvert65 [ Fri May 04, 2018 9:39 am ]
Aren't you supposed to put talcum powder in the tire for the slick and tube lubrication. At least with wrinkle wall slicks, I believe.
-Matt
Author:  Rob Simmons [ Fri May 04, 2018 11:14 am ]
I have also heard that people use either baby powder or dish soap when they don't use tubes in order to help from leak down.
Author:  Charrlie_S [ Fri May 04, 2018 11:34 am ]
My 23x10x13 inch slicks, leak thru the side wall, and there are no tubes available for them. I used Dawn dish soap on the inside. It helped, but didn't cure the problem. At least they don't go flat overnight. My 7x26x15 have tubes. Use talcum/baby powder, when using tubes. It lets the tube and tire slide, and prevents the tube from getting pinched.
Author:  slantzilla [ Fri May 04, 2018 4:00 pm ]
Heavy high horsepower cars and stick cars like tubes. That pretty much leaves most of us out.
Author:  Rick Covalt [ Fri May 04, 2018 4:11 pm ]
Interesting? But why is that? :?: :?:
Author:  slantzilla [ Fri May 04, 2018 6:16 pm ]
Because they beat the crap out of the sidewalls, especially if it's a heavy car.
