| Spark Plug Wires https://slantsix.org/forum/viewtopic.php?t=6230 |
| Author: | Daddiojoe [ Wed Jul 09, 2003 10:16 am ] |
| Post subject: | Spark Plug Wires |
WHo makes a good set and has anybody noticed much difference between stock and hi-po? Thanks, Joe |
| Author: | Jopapa [ Wed Jul 09, 2003 10:55 am ] |
I know Magnecor makes a set for the /6, Part# 6508, for 75 bucks. What I don't know is if they use larger boots on the distributor end, that our stock caps won't fit. This raises a question for me though, do the electronic distributors have larger towers to allow for bigger plug wires? |
| Author: | kesteb [ Wed Jul 09, 2003 2:11 pm ] |
No, they are the same as for the points distributor. I find that the cheap autolite plugwires work very well. |
| Author: | Pierre [ Wed Jul 09, 2003 2:42 pm ] |
I'm using MSD Superconductor 8.5mm wires along with a msd coil/box. They don't make a set specific for the /6 but I bought a universal v8 set and had to cut/crimp to my own desired length. This way I also have an extra 2 wires. Heck with all the extra wire length you can buy the terminals/boots seperately and make another set. |
| Author: | Slanted73 [ Wed Jul 09, 2003 10:16 pm ] |
| Post subject: | make yer own wires... |
I prefer making my own too, because you can route them exactly like you want. Besides, leftovers can make good wores for the riding lawnmowers lol. |
| Author: | Pierre [ Wed Jul 09, 2003 10:26 pm ] |
MSD wires for a lawnmower? heck no! way too expensive. I have about 3 or 4 used sets of /6 wires in the garage scatterd about if I ever needed any extra plug wires. All the universal sets I've seen were for v6 or v8's. The longest v8 wire easily has enough length for 2 /6 wires. |
| Author: | Daddiojoe [ Thu Jul 10, 2003 8:42 am ] |
Thanks everybody. I went with a $30 set of Accel 8mms that were universal for an 8. Crimped 'em up myself, and they still seem to work. Haven't noticed a big difference, but it does seem to run a little smoother. Joe |
| Author: | Jopapa [ Thu Jul 10, 2003 12:10 pm ] |
Quote: Thanks everybody. I went with a $30 set of Accel 8mms that were universal for an 8. Crimped 'em up myself, and they still seem to work. Haven't noticed a big difference, but it does seem to run a little smoother. Joe |
| Author: | Pierre [ Thu Jul 10, 2003 3:03 pm ] |
The only time you might see a improvment in driveablility/mileage/etc with a plug wire upgrade is if they were crossfiring in the first place. Good way to check that is to take a spray bottle and fill it with water or water and a bit of soap and spray all around the plug wire area while running, and see if you see sparks jumping from wire to wire. |
