Lean burn dist part #'s
https://slantsix.org/forum/viewtopic.php?t=62322
Page 1 of 1
Author:  OGLeanDart270 [ Wed May 09, 2018 7:18 pm ]
Post subject:  Lean burn dist part #'s
Anyone have part numbers for these so I can search for a NOS unit? Looking to go computer controlled ignition so I want to start with a distributor that is already locked out. Looking for either the single sensor or the dual as long as they have no advance mechanism.
Thanks
Brandon
Author:  DusterIdiot [ Wed May 09, 2018 8:00 pm ]
Post subject:  D
D
Author:  hank2 [ Thu May 10, 2018 10:58 pm ]
Post subject:  Re: Lean burn dist part #'s
I have a NOS dual pickup lean burn distributor I would sell reasonably. I'll have to dig it out of stored parts boxes. I had bought it before I decided to do the HEI conversion, a little down the road. I'll make sure I can find it and check the model/part no., then message you. If you haven't sourced one somewhere else. Mine would be considerably cheaper than any of the rebuilds or new on Rock Auto.
Author:  hank2 [ Fri May 11, 2018 11:03 am ]
Found mine. Mopar 4145751. Dual pickup, no vacuum advance. I had used the oem cap and rotor, so they're not included.
PM sent to OP.
