It is currently Fri Nov 13, 2026 5:01 am
 Post subject: Lean burn dist part #'s
PostPosted: Wed May 09, 2018 7:18 pm
Car Model: 1964 Dart 270
Anyone have part numbers for these so I can search for a NOS unit? Looking to go computer controlled ignition so I want to start with a distributor that is already locked out. Looking for either the single sensor or the dual as long as they have no advance mechanism.
Thanks
Brandon
____________________________
https://www.flickr.com/photos/162600228@N03/
 Post subject: D
PostPosted: Wed May 09, 2018 8:00 pm
D
PostPosted: Thu May 10, 2018 10:58 pm
Car Model: 1982 D150 225, 2bbl., 833 OD
I have a NOS dual pickup lean burn distributor I would sell reasonably. I'll have to dig it out of stored parts boxes. I had bought it before I decided to do the HEI conversion, a little down the road. I'll make sure I can find it and check the model/part no., then message you. If you haven't sourced one somewhere else. Mine would be considerably cheaper than any of the rebuilds or new on Rock Auto.
1982 Dodge D150 ( Ram)
225 with A833OD. 2bbl. Non power brakes
PostPosted: Fri May 11, 2018 11:03 am
Found mine. Mopar 4145751. Dual pickup, no vacuum advance. I had used the oem cap and rotor, so they're not included.
PM sent to OP.
