It is currently Sat May 02, 2026 1:16 am
PostPosted: Mon May 14, 2018 5:59 pm
Car Model: 1985 D100
I have a 1985 Dodge truck with the slant six. When i remove the valve cover to replace the gasket i see the fuel line looks in the way. Do i have to move it and if so can i take it off at the filter? Any other tips? thanks
PostPosted: Mon May 14, 2018 6:36 pm
Yes, and yes. Have something handy to plug the hose to the carb in case you get some drain back.
Have something handy to keep your cover bolts and washers in...have a magnetic probe handy in case you drop one.
If the gasket is fossilized a scraper will help strip most of that off the head.
PostPosted: Mon May 14, 2018 7:56 pm
Car Model: 1975 Dodge D100
Removing the valve cover with the fuel line in place is one of the advantages of the fuel line mod.
http://www.slantsix.org/forum/viewtopic ... 778#p92162
PostPosted: Tue May 15, 2018 4:43 am
Any chance someone can post a pic please
PostPosted: Tue May 15, 2018 2:30 pm
Click the red text. On this board red text is a link.
