It is currently Tue Nov 17, 2026 11:35 pm
PostPosted: Sat May 12, 2018 2:49 pm
Car Model: 1966 Valiant signat rag top
Hello all ,
Long time listener first time caller .
I’m putting together a 225 in my 66 Valiant signat rag .
I am using a Offenhauser 4bbl intake and a Holley 4160 390cfm on top .
My question is ,
With the stock pedal assembly that twist the throttle rod are you all able to use
The stock gas pedal with a cable ? I’ve read horror stories about the offy linkage .
Or would I be better off getting a cable pedal from a 70’s A body ? I really don’t want to
Drill holes in the fire wall .
Thanks all !!
PostPosted: Sat May 12, 2018 4:15 pm
That's the easy way.
I forget on the '66 if it's similar to the '67 pedal that's floor mounted with the cable attachment, if so, then you just swap out the cable with
one that is the correct length from a later car (up to 1974, or if you need 24"+ because the carb has the primaries facing the engine you can use one out of
a junkyard 90's chrysler minivan..)
If you are good with a welder and some scrap you can make a tab to hook link to and do that, but is adding some extra linkage that could be problematic.
PostPosted: Sat May 12, 2018 5:13 pm
If you can locate a V-8 pedal assembly from the 64-66 they had the cable instead of the twist/rod assembly.
PostPosted: Sat May 12, 2018 5:16 pm
I didn’t think to look In to like a 67,8,9 .
I got a pedal out of a mid 70’s dart and my pull n save this after noon .
Thanks for the input and good idea on the late model van cable ! Would have never
Thought of that .
PostPosted: Sat May 12, 2018 5:18 pm
Sweet !!! I have a 66 Barracuda v8 car I got for parts .
I figure they were the same set up .
You the man thank you !
PostPosted: Sat May 12, 2018 5:29 pm
Be sure and save you steering center link. Or give it to me! :D :D
PostPosted: Sun May 13, 2018 8:07 pm
Oh I know .
You in need of one ?
PostPosted: Mon May 14, 2018 3:17 am
I have one in my car but I know several folks on here are looking for them, Thanks!
Users browsing this forum: Amazon [Bot], Bing [Bot] and 5 guests
