It is currently Sat Nov 14, 2026 7:44 pm
PostPosted: Tue May 15, 2018 8:49 pm
I really like the look of the 65 dash panel, does anybody know if it will work in my 63 ?
Steve
PostPosted: Wed May 16, 2018 2:03 am
Do you mean the entire dashboard and every thing under/inside it, or just the gauge cluster? I believe that either way you can swap parts around. It's possible you might have a larger cluster hole in the 63 dashboard, but I think they are the same.
PostPosted: Wed May 16, 2018 9:06 am
I meant just the gauge cluster .
