It is currently Sat Apr 25, 2026 3:35 pm
PostPosted: Mon Apr 09, 2018 6:44 am
Car Model: 1985 dodge d150 225cid 3.7l
1985 dodge d150 225cid 3.7l changed from lean burn to hei ignition system still using lean burn carburetor does anybody know what carburetor I can use on factory manifoldto get rid of lean burn carburetor don't want to change factory maniford if possible please reply thank you reddog
PostPosted: Mon Apr 09, 2018 7:18 am
A quick search on this site will yield lots of conversations about this very thing. A decent Holley 1920 is hard to find these days, but it will bolt on if you use the correct choke pieces. A Holley 1945 IIRC is a direct replacement. When I did the Lean Burn to HEI swap I tossed on the latter and had no problems.
PostPosted: Sun Apr 22, 2018 11:53 am
I have a very good 1974 Dodge truck/van Carter BBS carb, in-box, on my shelf. It is drop-on compatible and will work well on your '85—except it would want a Carter-type choke thermostat, which is just as well because whether you stay with a 1945 or go to a BBS you would be much(!) happier replacing the not-very-good factory choke thermostat and controller with one of the Electric choke kits. № 1231 if you get the BBS carb, or № 1234 if you use a Holley 1945. These electric chokes, unlike the factory items, are adjustable which allows enormous improvements in cold-start/cold-drive behaviour.
Send me a PM if you wish to buy the BBS.
PostPosted: Sun May 20, 2018 9:39 pm
Car Model: 1982 dodge ram
I would be interested in BBS.
Pm sent.
