| Exhaust under oil pan https://slantsix.org/forum/viewtopic.php?t=62390 |
| Author: | Mongrel147 [ Wed May 23, 2018 12:54 pm ] |
| Post subject: | Exhaust under oil pan |
Thanks for the info about running my exhaust under my oil pan. I was actually surprised that it was a factory item. The diagram really helped, BUT, when I went to NAPA to see about the pipe it is no longer available. Part number 31307 by the pipe in the diagram is for the gasket. Any idea where I can get one of these reasonably. Prefer new too. I'm located in central Illinois. By the way, the diagram comes from NAPA's old exhaust "book" catalog, not on their computer. |
| Author: | sandy in BC [ Wed May 23, 2018 1:16 pm ] |
| Post subject: | Re: Exhaust under oil pan |
Find an old exhaust shop. They may have the card to bend you a new one. |
| Author: | tophat [ Thu May 24, 2018 5:13 pm ] |
A "good" exhaust man can bend it without a "bend card". Find a good custom exhaust shop. I would tell you to bring it to where I work, but SC would be a bit of a drive for you. We would charge you somewhere between $100 and $150 for the pipe, installed. |
| Author: | slantzilla [ Thu May 24, 2018 9:30 pm ] |
Call Jeff Long in Paxton. 217/379-4415. He probably has the card for it. |
| Author: | Greg Ondayko [ Fri May 25, 2018 4:45 am ] |
| Post subject: | Re: Exhaust Card |
The skilled Tech should refer to and use one of these for the build you require. ![]() Greg |
