| dropped condensor screw down into dist https://slantsix.org/forum/viewtopic.php?t=6240 |
| Author: | sixanator [ Thu Jul 10, 2003 6:41 am ] |
| Post subject: | dropped condensor screw down into dist |
I think that little pesky screw fell in there during a recent point swap, do I have to get it out? the car is running fine (right now), what will happen as far as damage? |
| Author: | slantvaliant [ Thu Jul 10, 2003 7:52 am ] |
I really don't like the idea of little bits of metal rattling around loose anywhere in the car. I'm not sure what harm it could do, but why risk finding out? I'd pull the distributor, invert it, and see if I couldn't shake the screw out. You'll have to reset the timing, but that's not a big deal for piece of mind. |
| Author: | killin5 [ Thu Jul 10, 2003 9:05 am ] |
I think I got one out one time with one of those magnets on a stick type of things you get at the auto parts store. John |
| Author: | Dennis Weaver [ Thu Jul 10, 2003 10:15 am ] |
You must have more patience/dexterity then I do, changing the points/condenser on a /6 with the distributor in place! What body is it in? Here's a tip. Next time you gotta change points, spin the motor so the rotor points at exactly 12 o'clock, or some other easily memorable direction. Mark the bracket where the bolt for adjusting the timing is located with a piece of chalk, or simply drag a screwdriver through the grease "DW" |
| Author: | Eric W [ Thu Jul 10, 2003 11:06 am ] |
Better yet, change to factory electronic ignition or put a Pertronix electronic ignitionkit in it. Never change points again! I pulled the distributer to change points (when I had them) also. Electronic is pretty much set and forget. |
| Author: | Guest [ Thu Jul 10, 2003 8:23 pm ] |
Thanks, I am going to go the EI route, just buying some time first. It's in a 71 valiant. I don't have a timig light so I'm going to try the magnet option first. |
| Author: | Eric W [ Thu Jul 10, 2003 9:26 pm ] |
Best place to get a timing light is a pawn shop. I only paid 20 bucks for my Sunpro dial back light! |
| Author: | Doctor Dodge [ Thu Jul 10, 2003 11:27 pm ] |
I will cut you a deal on these tools: http://www.slantsix.org/forum/viewtopic.php?t=5729 DD |
