1975 Duster transmission; is it supposed to have a mount?
https://slantsix.org/forum/viewtopic.php?t=62405
Author:  Plymouth_Ruster [ Sun May 27, 2018 6:28 pm ]
Post subject:  1975 Duster transmission; is it supposed to have a mount?
Just got done taking the engine out of my 1975 duster, and my dad and I noticed that the transmission isn't really mounted to anything but the engine. Is this correct, or is it supposed to be bolted to something that isn't there?
Author:  Charrlie_S [ Sun May 27, 2018 6:50 pm ]
Post subject:  Re: 1975 Duster transmission; is it supposed to have a mount?
There should be a cross member, between the torsion bar anchors. A rubber mount on top of the cross member, to the bottom of the transmission tail shaft housing.
Author:  DusterIdiot [ Sun May 27, 2018 7:33 pm ]
Post subject:  D
D
Author:  Charrlie_S [ Mon May 28, 2018 2:02 am ]
This is a late A-body so the mount is as Charlie says, but it has a rubber cylinder behind the crossmount with a
single bolt through it (called a spool mount similar to the way your motor mounts work),
Thanks, DI. I'm so used to the earlier setups, I forgot about the change to the spool mount.
Here is a picture
https://www.rockauto.com/info/60/A2512_01__ra_p.jpg
Author:  rich006 [ Tue May 29, 2018 9:06 am ]
Here are a couple of pictures I took of mine ('74 Dart). The red arrows show where the bolts should go (mine were missing).
Viewed from the rear:
Viewed from beneath:
