| Waats uh.... the difference https://slantsix.org/forum/viewtopic.php?t=62436 |
| Author: | hank [ Sun Jun 03, 2018 7:33 am ] |
| Post subject: | Waats uh.... the difference |
Can anyone tell me the differance between the throttle pressure and line presure adjustment screws in a A904? ( 1986) I am thinking throtle pressure is when it shifts and line pressure is working pressure to the valves and servoes?? Is this a correct analysis? And does higher line pressure mean higher throttle pressure is required to shift at the same rpm? And vice versa? |
| Author: | Badvert65 [ Sun Jun 03, 2018 8:22 am ] |
| Post subject: | Re: Waats uh.... the difference |
Throttle pressure balances itself against the pressure regulated by the governor. |
| Author: | hank [ Sun Jun 03, 2018 12:08 pm ] |
So . If l adjust the govenor pressure or change the diff gears ( currently 2/45s ) that will change the govenor pressure hence changeing the rpm the trany will shift at.. at wot. |
| Author: | slantzilla [ Tue Jun 05, 2018 10:23 am ] |
Line pressure is set with an adjuster on the valve body. Throttle pressure is set with the kickdown linkage. |
