It is currently Mon Nov 16, 2026 1:01 pm
 Post subject: Missing linkage clip?
PostPosted: Thu Jun 14, 2018 4:20 am
Car Model: 72 valiant
Hello,
Recently while replacing intake/exhaust manifold gasket, while reassembling the kick down linkage,
I noticed there appears to be a missing clip.
This is the arm (bellcrank?) that attaches to the kickdown rod. There appears to be a missing clip or something else that keeps the rod in place. I do not believe there was anything in place during disassembly.
Any ideas, or possible picture. I could not find an illustration although all I have is the Chilton shop manual .
Thankyou
PostPosted: Fri Jun 15, 2018 5:08 am
Hello,
I searched illustrated views of the linkage assembly , but zooming in to blurry pictures was unable to determine what exactly the clip, or correct component looks like .
What I did is what I should've done five or six years ago I went on eBay and I purchased a correct shop manual which probably should arrive shortly
. I still am left wondering how for so many years this car has run and drive as well as it has with no transmission issues .
PostPosted: Sat Jun 16, 2018 6:22 am
Online
It would help considerably if you could post a picture of the rod with the missing clip.
It is likely one of these., I don't know the proper name for it.
Dorman # 41016 is an assortment.
http://i.ebayimg.com/images/i/161179956 ... -l1000.jpg
You can find these at most hardware or auto part stores.
