| HEI conversion Confusion FD478 Coil https://slantsix.org/forum/viewtopic.php?t=62508 |
| Author: | Philip's66 [ Sat Jun 23, 2018 7:39 pm ] |
| Post subject: | HEI conversion Confusion FD478 Coil |
I am going to do the HEI conversion on my 66 Dart Slant Six , Have all the parts on hand . What confuses me is the connections on the FD 478 coil. It has 1 positive wire and 2 Negative wires.The terminals are marked+and-. How do I connect the relay to the positive side -just splice it in or pull the connector and add another wire? I assume one wire on the negative side goes to C connection on the module and one wire connects to the negative from the coil. Am I not seeing things straight?What am I missing? I Prefer to use the relay ,but I read that it can run without it. Thank You for your help in Advance. Philip's66 |
| Author: | Philip's66 [ Sat Jun 23, 2018 9:01 pm ] |
| Post subject: | Re: HEI conversion Confusion FD478 Coil |
Please forgive me ,i was thinking too hard ,too long ,having a brain fart. |
