| Z-bar ball stud https://slantsix.org/forum/viewtopic.php?t=62514 |
| Author: | dirtyd100 [ Sun Jun 24, 2018 6:28 pm ] |
| Post subject: | Z-bar ball stud |
I am trying to install my new A833 OD trans and I need some help. My truck had an A903 3 spd with a different Z-bar than what I need for my new 4 spd. Two questions: 1. Can I reuse the old ball stud that the z-bar mounts to the bell housing on the new set up? 2. Where does the new z-bar mount on my truck? I have the mounting tab for the new trans (thanks DI) but I do not see anywhere that it should mount to on the frame or cab of my truck. Will I need to change anything else with this swap. Thanks |
| Author: | DusterIdiot [ Sun Jun 24, 2018 7:51 pm ] |
| Post subject: | D |
D |
| Author: | dirtyd100 [ Mon Jun 25, 2018 6:18 pm ] |
| Post subject: | Re: Z-bar ball stud |
Thanks DI, you would not happen to know where to find one of those A833OD brackets might be located? Can I use one from a V-8 truck or car? There is a pull a part yard not far from me that has a 318 truck with a busted up OD trans. |
| Author: | DusterIdiot [ Mon Jun 25, 2018 6:54 pm ] |
| Post subject: | D |
D |
| Author: | dirtyd100 [ Mon Jun 25, 2018 8:40 pm ] |
Will any other transmission work? NP435/445 maybe? |
| Author: | DusterIdiot [ Tue Jun 26, 2018 6:11 am ] |
| Post subject: | D |
D |
| Author: | dirtyd100 [ Wed Jun 27, 2018 6:28 pm ] |
I might have a couple of those at my buddies salvage yard. Thanks for all the help. Zeb |
| Author: | SketchyJeff [ Wed Jul 11, 2018 8:44 pm ] |
If you haven’t had any luck finding what you need, I have a z bar and brackets from an ‘84 truck with a slant and a833 I’d be willing to part with. |
| Author: | dirtyd100 [ Fri Jul 13, 2018 2:37 pm ] |
I rigged mine up with the 3 spd body mount and a z bar and bell mount. It is not pretty and not straight, but it works fine and the clutch action seems to work fine. I would like to actually see a pic of one all hooked up and working properly. |
