It is currently Wed Nov 25, 2026 7:20 am
PostPosted: Mon Jul 07, 2003 10:56 pm
I was reading Doug's gear failure article again and figured that instead of buying a whole new oil pump, I'd see about reworking the original pump and then check into getting a hardened gear for it (I'll hit you up offline once I get up to that point Doug).
Anyway I had some questions after going over it again.
For drilling out the passageways, what's the optimal size to drill them out to?
What do I want to set the relief valve to, and how exactly do I do this?
And as for this pic:
What's up with all the grinding and cutting tools? This seems like a pretty involved process for an oil pump.
Also, for adding a cam stop button, what exactly is the best way to acheive that? The rocker arm screw looks like a good idea, but what size bolt do I want for it, and what's the best way to set something like this up?
 Post subject: Oil Pump Reworking...
PostPosted: Wed Jul 09, 2003 12:15 am
The SL6 oil pump is pretty easy to "blueprint".
The biggest challenge is getting the gear off so the unit can be completly disassembled.
The passages should be drilled to 1/2 inch.
All the cutters and special tools help make the job easy and the outcome nice. Having the right shape cutter just allows good access and produces an even cut. For an oilpump, I use the 1/2 "oval" and the 5/8 ball cutters the most.
Setting the releif valve is a trial & error process, I just use the factory spring and adjust it as needed. (add shims between the spring and the endplug) Monroso ofers a exturnally adjustable end plug for Mopar bigblocks / Hemis which also works on the SL6
Seems like a lot of people just send me their pump and payto have it reworked.
I drill-out all the passageways, blend-in all the sharp edges and add the hardened gear. If you only plan to build one oil pump then it may not make sense to buy all the special tools needed to do the job.
PostPosted: Wed Jul 09, 2003 12:30 am
Awesome. I think I can tackle this job myself then. I'm hoping I can just rework this pump and up the pressure a bit (you think 30-40 PSI oughtta do it for a /6?), then get a hardened gear from you instead of getting a whole new pump.
So do you add shims to up the pressure?
PostPosted: Wed Jul 09, 2003 8:49 am
With the factory 5/8 impeller thickness pump, 30-40 psi at hot idle is common with 50-55 psi at engine speeds over 1600 to 1800 rpm.
Keep the max pressure limited to the 50 to 55 psi range for you average SL6.
PostPosted: Wed Jul 09, 2003 9:51 pm
Hey Doug I checked Moroso for that adjustable valve for our oil pumps but I can't find it anywhere. What would it be listed under?
PostPosted: Wed Jul 09, 2003 11:30 pm
Errrr....may-be it's a Milidon part, adjustable releif valve plug.
I have the part number somewhere, I will need to do some digging to se if I can find it.
PostPosted: Sat Jul 12, 2003 7:22 pm
Cool. My goal is to be able to run 10W-40 synthetic and keep full pressure with a reworked pump and fresh screen.
