| speedometer https://slantsix.org/forum/viewtopic.php?t=62537 |
| Author: | '67 Dart 270 [ Sat Jun 30, 2018 7:08 pm ] |
| Post subject: | speedometer |
I have a '67 dodge dart 2 door hardtop. My speedometer has a male threaded connection for the speedometer cable. I also have a speedometer that appears to be the same, fits in my gauge cluster, but does not have the threaded connection at the rear, rather it has what appears to be a quick connect type connector, similar to an air hose. Anyone know what year that other speedometer is? I can dig it out of my stuff and get a part number if that helps. Brian |
| Author: | Michael [ Sat Jun 30, 2018 7:56 pm ] |
| Post subject: | Re: speedometer |
67 was a transition year for the speedo connector. IIRC 68 and forward got the push-on connector and you need only order the later cable to adapt it to your 67. Others here will have more definite info. |
| Author: | '67 Dart 270 [ Sat Jun 30, 2018 8:37 pm ] |
Thank you, Michael. Add that to the list of differences between '67 and '68 onward darts.... brian |
