It is currently Sat Apr 25, 2026 10:22 am
PostPosted: Sat Apr 21, 2018 9:12 am
So, is there a special tool for installing the sprocket that goes on the crankshaft?
Or, does it just slide on, with a little "persuasion"?
Thanks!
'78 Volare 225
'67 Charger 318
 Post subject: D
PostPosted: Sat Apr 21, 2018 9:29 am
D
PostPosted: Sat Apr 21, 2018 10:15 am
Okay, thanks!
So, put the crank sprocket on first, then the timing chain and other sprocket?
'78 Volare 225
'67 Charger 318
PostPosted: Sat Apr 21, 2018 10:22 am
crank first
.....then you have to get the cam timing right.
lazy way:
roll the crank to #1 TDC
roll cam to close intake and exhaust valves on #1
Bolt on cam gear and chain without disturbing cam or crank.
Using degree wheel ensure cam timing is correct.
PostPosted: Sat Apr 21, 2018 10:47 am
Ugh, can't get it on all the way.
I'll try again after work...
'78 Volare 225
'67 Charger 318
PostPosted: Sat Apr 21, 2018 11:05 am
You can use a piece of pipe, that slides over the crank snout. Big washer/something, and the crank bolt, and push the sprocket on. I actually have an old crank pulley hub, that is honed out to a slip fit. I can use that to press the sprocket, and also use to mount the degree wheel. Key way keeps it from slipping, but if I have to remove the degree wheel for any reason, it just slides off and back on in the same position.
PostPosted: Sat Apr 21, 2018 11:09 am
Thanks Charrlie!
'78 Volare 225
'67 Charger 318
PostPosted: Sun Apr 22, 2018 12:41 pm
Well, the bolt will not thread into the crankshaft.
The sprocket is not on far enough, and now I can't remove it.
Any suggestions?
'78 Volare 225
'67 Charger 318
 Post subject: D
PostPosted: Sun Apr 22, 2018 3:44 pm
D
PostPosted: Sun Apr 22, 2018 4:36 pm
Why won't the bolt screw into the crank? Are the threads messed up? Need to fix it. Otherwise, how are you going install the crank damper?
PostPosted: Sun Apr 22, 2018 5:06 pm
Ok, removed the pulley using a puller, so I'm back where I started.
Good question Charrlie, not sure. I think its the threads inside the crankshaft.
So, should I chase the threads?
Thanks for the replies fellas!
'78 Volare 225
'67 Charger 318
 Post subject: D
PostPosted: Sun Apr 22, 2018 7:27 pm
D
PostPosted: Mon Apr 23, 2018 10:05 am
I am assuming the crank is in the car / engine?
There is a Harmonic Dampener install tool that I like to use for this situation..
Works with dampeners and Lower Timing gears - Some times the lower gear needs to be sanded a bit to get the proper press fit.
https://www.summitracing.com/parts/sum-g1023-1
the one I have is not available but this does similar.
Heating can help as other posters had mentioned.
PostPosted: Mon Apr 23, 2018 8:26 pm
Car Model: 66 Valiant, 82 D150, 94 Ram 2500 TCD, 69 Dart
Wes,
I'm getting ready to do a timing chain on my 82 D150. I knew my crank bolt would not be long enough to reinstall the harmonic balancer, and anyway I didn't like the idea of using a bolt with the crank female threads providing the the pulling power to install the balancer. So I bought a big piece of 3/4-16 allthread and cut it into 6" chunks. Now I can thread the all-thread fully into the the crank with a double-nut to anchor the rear end and keep it from rotating. Then, using one additional nut with a washer to drive on the balancer I'm home free. This should work fine to install both your gear and balancer. I have several more of these I will not need so if you want one, PM me to discuss. I'd sell one for peanuts plus shipping.
PostPosted: Mon Apr 23, 2018 8:39 pm
Oops. Also forgot to mention I have a flat bottom 3/4-16 tap I'd be happy to loan you to chase your threads.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
