It is currently Wed Nov 25, 2026 1:27 pm
 Post subject: Lash Settings
PostPosted: Wed Jul 16, 2003 2:20 am
Here's a question for all you cam experts. Some years ago when I put the "Competition Cams" cam in my Duster, it came with a little card with all the specs. It called for lash to be set at .010" Intake, and .012" Exhaust, hot. The exhaust spec seemed tight to me, and thinking it might be a typo I even went so far as to call the Comp Cams tech line where they assured me that it is correct. I set everything as prescribed and have maintained these settings with no ill effects that I know of. I have always had a small bit of lingering doubt. What say some of you? And what determines how much lash a specific mechanical cam will require in the first place?
"DW"
If it ain't broke, fix it!
PostPosted: Wed Jul 16, 2003 11:31 am
Yup, those lash settings are correct, just use what ever the man. requires :), if you feel that bad about it you can set it to .12 on intake and .14 on the exhaust hot, that'll "bleed" off the cam a bit and you'll get alittle more noise.
I'd just leave it set at what it is :)
Justin
Users browsing this forum: Amazon [Bot], Bing [Bot] and 7 guests
