It is currently Wed May 06, 2026 1:17 pm
 Post subject: Fuel line size?
PostPosted: Sun Jul 29, 2018 11:10 am
Car Model: 1965 Dart
What size fuel line to run for a modified Slant six with a 400 CFM carburetor? standard was 5/16 do I need to upgrade to 3/8?
Thanks. Brian
 Post subject: Re: Fuel line size?
PostPosted: Mon Jul 30, 2018 6:07 am
I run 5/16" with Holley 390, 225 engine spins up to 6000+ rpm (before rebuild this year) and runs out of carb before fuel. Now if you are racing circle track or some other activity requiring constant very high rpm, perhaps 3/8" may be required.
PostPosted: Mon Jul 30, 2018 3:56 pm
Thanks supercharged! No racing just wanted to make sure I don't run out of fuel when I play hard!
PostPosted: Mon Jul 30, 2018 6:42 pm
Stock 5/16" line supports 11 second race engine. It will be fine for all but the wildest blown and turboed alchohol engines.
PostPosted: Mon Jul 30, 2018 8:39 pm
On the other hand a stock replacement fuel pump and 5/16 fuel line was unable to keep the fuel bowls full on a low 17 second 225. So your results will depend your setup. And the only way to know it to try it and see.
Users browsing this forum: Bing [Bot], Dart270 and 11 guests
