| Valves? We don't got no stinking valves! https://slantsix.org/forum/viewtopic.php?t=62669 |
Page 1 of 2 |
| Author: | coconuteater64 [ Fri Aug 03, 2018 10:10 am ] |
| Post subject: | Valves? We don't got no stinking valves! |
I'm finally to the point where I'm ready to build a cylinder head. This is for the engine going in my D100, and is as follows so far: 198 block bored to 87.5mm for 2.2 dished pistons 225 crank 198 rods Oregon Cams 2106r regrind A833OD with 3.55 rear gears Dutra duals Holley 350cfm 2 barrel carb It's going to be a highway machine that pulls a small teardrop camper through the mountains, and the occasional boat. It'll also see occasional city driving. I've been looking all over for some 1.70 and 1.44 valves, but I have come up with nothing so far. What options do I have? Should I just put in new, stock sized valves and do a little porting? Or will that be more work than it's worth? I read on an old FABO post that somebody was going to try a Ford 289 valve, and others have mentioned a BB Mopar exhaust being ground to 1.80 for the intake. That seems awfully close to the cylinder wall to me, and what about the exhaust? |
| Author: | Joshie225 [ Fri Aug 03, 2018 10:20 am ] |
| Post subject: | Re: Valves? We don't got no stinking valves! |
http://www.sivalves.com/valves.html |
| Author: | sandy in BC [ Fri Aug 03, 2018 10:23 am ] |
I used 1.72/1.50 SBC valves . They are a bit taller and mandate the use of new pushrods. I got the machine shop to give the head a bowl hog at the same time. ….and I used SBC valve springs and keepers. Way cheap and the machine shop was relieved to be doing a Chev job...…. |
| Author: | DadTruck [ Fri Aug 03, 2018 10:38 am ] |
Quote: 198 block
that must be the 198 motor that found its way from Indiana to George for valves I am building a slant head using Ford 298 valves Intake: SEV2564 1.780 Exhaust: SEV2563 1.45 the Ford valves have a .342 valve stem stock slant six is .375 so new guides will be required. the Ford stem length is 4.870 slant six standard length is 4.774 the Ford valves are .096 longer, I'll find out as the motor goes together what the additional .096 will do, but I am thinking that the slant six adjustable valve train will accommodate it. I have also read of folks using stock mopar 318 valves, you get a bump in valve size and retain the .375 valve stem diameter. The 318 valves are also longer than the slant six valve. Mike Jefferis ran Chevy valves with the OD cut down to the 1.7x and 1.4x diameter. I believe that WV has a set of those that he could provide dimensions on to figure out what Chevy valve was being used. MJ said he liked the Chevy valves because they were cheap. |
| Author: | coconuteater64 [ Fri Aug 03, 2018 11:02 am ] |
Quote: Quote: 198 block
that must be the 198 motor that found its way from Indiana to George |
| Author: | coconuteater64 [ Fri Aug 03, 2018 11:15 am ] |
Quote: http://www.sivalves.com/valves.html
Thanks! I looked at the catalog and saw the 1.77 intake and 1.44 exhaust valves, but no price listed. Look to be good pieces.Quote: I used 1.72/1.50 SBC valves . They are a bit taller and mandate the use of new pushrods.
Is there enough metal in the head to do much of a bowl hog before it strikes water? My local shop mainly makes circle track Chevrolet engines, so I'm sure they have all the stuff to do that.
| Author: | Rob Simmons [ Fri Aug 03, 2018 11:25 am ] |
Or this? http://www.slantsix.org/forum/viewtopic.php?f=8&t=62289 Charlie has a set of oversize valves for sale. |
| Author: | SpaceFrank [ Fri Aug 03, 2018 12:47 pm ] |
Quote: Or this?
I'm the "pending sale." It's coming with some other stuff, and I'm waiting on a shipping quote from Charlie.
| Author: | coconuteater64 [ Fri Aug 03, 2018 12:57 pm ] |
Quote: Quote: Or this?
I'm the "pending sale." It's coming with some other stuff, and I'm waiting on a shipping quote from Charlie.http://www.slantsix.org/forum/viewtopic.php?f=8&t=62289 Charlie has a set of oversize valves for sale. |
| Author: | Rob Simmons [ Fri Aug 03, 2018 1:27 pm ] |
| Author: | DadTruck [ Fri Aug 03, 2018 1:42 pm ] |
Quote: idea DadTruck has about the Ford 289 valves
I got the idea and the valves from Josh 225
| Author: | Rick Covalt [ Fri Aug 03, 2018 1:45 pm ] |
Quote: Is there enough metal in the head to do much of a bowl hog before it strikes water?
Not much! Especially between the intake and exhaust ports. Ask me how I (And others) know! I have photographic evidence of the mishap if needed! |
| Author: | coconuteater64 [ Fri Aug 03, 2018 4:59 pm ] |
Quote: Quote: Is there enough metal in the head to do much of a bowl hog before it strikes water?
| Author: | Badvert65 [ Fri Aug 03, 2018 6:59 pm ] |
Mopar big block exhaust valves (Sealed Power #V1900) are 3/8" stem, 1.74" dia and are only 0.100" too tall. I am using a set as intake valves on my slant head. I can easily shave off the extra length to keep everything even height-wise. |
| Author: | and739 [ Fri Aug 03, 2018 8:04 pm ] |
Quote: Quote: Quote: Is there enough metal in the head to do much of a bowl hog before it strikes water?
| Page 1 of 2 | All times are UTC-07:00 |
