It is currently Wed Nov 25, 2026 11:04 am
PostPosted: Mon Jul 14, 2003 10:06 pm
Well I made an idiot of myself and left the Dart with the key in the ACC position when I left the girl's place yesterday. So for both her and my benefit, I figured it'd be a good idea to install a small idiot light for when the ACC circuit is on but the engine isn't running.
Seems like it'd be pretty easy to tap it into a circuit that's only active when the car is on but the engine isn't running. I thought about tapping it to the oil lamp, but I don't want both lamps coming on when the oil pressure gets low, so what's another way I could wire a simple 12V light up?
PostPosted: Mon Jul 14, 2003 10:13 pm
Heres something thats easier to do. Take the keys out of the ignition when you get out of the car. :shock:
PostPosted: Mon Jul 14, 2003 10:41 pm
Yes one would think, but then there are those occasions when I or someone else will pull a Homer Simpson and do something that makes us smack our foreheads in frustration :roll:
PostPosted: Tue Jul 15, 2003 1:54 am
The heater blower or radio lead are a pretty good choices.
Also look at the fusebox, many times there is an extra "ACC" spade already there, just waiting for a new wire. Get out your test light and start checking some of the leads comming off the fuse box.
PostPosted: Tue Jul 15, 2003 12:34 pm
New cars are full of "homer simpson" fixes, thats why the whine, buzz, talk and completely annoy the hell out of you. It would be simpler to take the keys out of the ignition. One or two dead batters is all it takes...
PostPosted: Tue Jul 15, 2003 12:46 pm
Wire to the hot side on the IGN ON spade on the fuse block if possible.
PostPosted: Tue Jul 15, 2003 1:10 pm
Yeah I hate the noises too. That's why I wanna put in a light instead of a buzzer (gotta love those buzzers that Ford uses)
