| Found these pistons https://slantsix.org/forum/viewtopic.php?t=62688 |
| Author: | Vgute [ Tue Aug 07, 2018 4:24 am ] |
| Post subject: | Found these pistons |
So was given these pistons- TRW L3012F and are 30 over, googled them as you do, did not find much? |
| Author: | Doctor Dodge [ Tue Aug 07, 2018 12:25 pm ] |
| Post subject: | Re: Found these pistons |
That sounds like a Mopar 318 piston part number. Measure across the head, it should be close to 4 inches. (3.938) Were there 8 pistons in the set? DD |
| Author: | Greg Ondayko [ Tue Aug 07, 2018 12:41 pm ] |
Good to see you on here doc. Hopefully the fires are not by your house. Greg |
| Author: | Vgute [ Tue Aug 07, 2018 3:53 pm ] |
Hey everbody, six pistons in the box, inside was a data chart, L-3012F is listed as 3.400" which is what i got, took somes pics, but need to find out how to link off google drive. |
| Author: | Doctor Dodge [ Tue Aug 07, 2018 5:11 pm ] |
My bad, the TRW 318 piston is L3013F As for the CA fires, those are 60 & 100 miles North of us at the moment. DD |
| Author: | DadTruck [ Tue Aug 07, 2018 5:25 pm ] |
Quote: L-3012F is listed as 3.400"
you may want to mike the pistons to verifybut 3.400 is the OE stock size bore, slants needing a rebuild typically need a .020 or .030 or more overbore and over sized pistons/rings to match you will need to find a NOS block or have a used block sleeved to use those pistons. if they are not OS,, don't trash em,,some folks like having old stuff around, or make bookends or trophies from them.... |
| Author: | Greg Ondayko [ Tue Aug 07, 2018 5:43 pm ] |
Cool. 60 miles is still too close for those fires. Best wishes that they get those contained soon. Now back to piston talk. Greg |
| Author: | Vgute [ Tue Aug 07, 2018 7:15 pm ] |
Quote: Quote: L-3012F is listed as 3.400"
you may want to mike the pistons to verifybut 3.400 is the OE stock size bore, slants needing a rebuild typically need a .020 or .030 or more overbore and over sized pistons/rings to match you will need to find a NOS block or have a used block sleeved to use those pistons. if they are not OS,, don't trash em,,some folks like having old stuff around, or make bookends or trophies from them.... You know i was just waiting for someone to reply with this, pistons are 30 over, but yes you are correct if they were L-3012F , but they are L-3012F-30. |
| Author: | Vgute [ Tue Aug 07, 2018 7:42 pm ] |
Hey just out of interest, does the "F" stand for forged? Had a look on the net, some say yes and some say no? |
| Author: | emsvitil [ Tue Aug 07, 2018 8:07 pm ] |
Quote: Hey just out of interest, does the "F" stand for forged? Had a look on the net, some say yes and some say no?
In this case...…...NoI found my old TRW catalog Pistons: L prefix Alloy piston 100-400 series powergroove 500-1900 cast aluminum 2000 series with F suffix power forged 2000 series with CF suffix cast aluminum 3000 series with F suffix cast aluminum decompressed F suffix pin fitted CF suffix cast aluminum pin fitted KF suffix piston and rings pin fitted HF suffix hyperteutectic alloy pin fitted |
| Author: | DadTruck [ Wed Aug 08, 2018 6:34 am ] |
.030 over pistons would be useable, I would still have them checked for diameter so you know exactly what you have Quote: cast aluminum decompressed
I know that the molten aluminum used to cast pistons is degassed, I have never heard the term 'decompressed' used with cast aluminum pistons. Is there any additional info in the TRW catalog concerning the 'cast aluminum decompressed'? |
