It is currently Tue Nov 17, 2026 8:39 pm
PostPosted: Sat Aug 04, 2018 3:40 am
I have a 61' Valiant with a later type Carter dual barrel carbie fitted to the slant 6.
The car is driven infrequently, about once a fortnight, and is hard to start as the fuel has drained/evaporated from the carbie. (If I pour a little fuel into the carbie it starts easily).
What can I do do prevent the evaporation from happening?
PostPosted: Sat Aug 04, 2018 4:14 am
I put a facet style electric pump next to the tank so I can prime the system. You can keep it off after priming.
PostPosted: Sat Aug 04, 2018 7:10 am
If you pour gasoline into an open container and leave for a fortnight, I expect very little of it will remain and remainder probably won't vaporize easily. With a working charcoal canister vapor recovery system, at least some of the vaporized fuel could be recovered but that won't help your starting issue.
You could set up an electric pump to run only on ignition start using relays (get them from Daniel Stern Lighting). I have list of suitable priming pumps here: Vapor Lock. If you add relays, that would be a good time to do the HEI Ignition Upgrade.
1965 Plymouth Barracuda,
225 engine, Quadrajet, HEI, Dutra Duals, 904 Torqueflite, 2.76:1 axle, Addco front bar
Rods & Relics - Fort Erie, ON / Collector Car Tech
PostPosted: Sat Aug 04, 2018 12:31 pm
Do what the factory did- install a charcoal cannister and a closed air cleaner. This will help contain the petrol vapors a bit, but I don't think any device will retain the vapors for a fortnight (two weeks to us Yanks). Just about any carburetor will evaporate dry if left untouched for that long. The electric fuel pump priming is about the only way to get rid of that problem.
PostPosted: Thu Aug 30, 2018 4:46 am
I now remove the air cleaner and pour a small volume of fuel into the carby vent tube which fills the bowl. My car starts easily now.
