| Replacing spring on door hinge. https://slantsix.org/forum/viewtopic.php?t=62726 |
| Author: | Batesy [ Sat Aug 18, 2018 7:44 am ] |
| Post subject: | Replacing spring on door hinge. |
Anyone in here ever done this? I picked up a spring that is missing on my driver door hinge. Anyone able to tell me the steps on removing the door and putting the new spring in? Thanks |
| Author: | hyper_pak [ Tue Aug 21, 2018 6:16 pm ] |
| Post subject: | Re: Replacing spring on door hinge. |
Should not have to remove the entire door, loosen both, block door with a floor jack and take out the one you need to work on, with them both loose you should be able to fish it out. |
