more turbo questions
https://slantsix.org/forum/viewtopic.php?t=6275
Page 1 of 1
Author:  welly225 [ Mon Jul 14, 2003 11:17 am ]
Post subject:  more turbo questions
Hey all,
been reading your stuff for a while now and finally decided I had to jump in. I've got a handful of 225's (pre-76) sitting in the backyard as well as a couple turbo 2.2's. Anybody got any ideas about putting these two together? I've read all the articles and threads here about turbos and efi conversions and I'm in the process of reading Maximum Boost. After talking to a buddy of mine (building a 240Z with a twin turbo Skyline mill out of Japan, very cool and quick), I've come to the conclusion that I've got to try something like this.
The main questions I have are as follows?
Can I build a twin turbo slant 6 (EFI?) with salvage yard parts?
Can I expect to fit all this under the hood of my 68 dart?
Has anybody ever done anything like this?
Will this engine rival a big block for power/performance? (My other option is a running hand-me-down 383, but if I wanted to do that I wouldn't be writing this would I).
Unfortunately it needs to be salvage yard parts for now as the rest of the car is at the body shop and it's not going to be easy on the wallet.
thanks
Author:  kesteb [ Mon Jul 14, 2003 1:10 pm ]
Yes, but a single turbo would be perforable. Some people are using Buick stuff to make it happen. You will need to start with 30lbs injectors to make it work. I would use Mustang EFI parts, rather cheap and plentiful. I would use a MegaSquirt for the ECU.
Yes, there is no reason why it can't. I fully suspect my setup to nestle down by the engine block.
Yes, several people, do a search on "turbo". Also check the .com site.
I have been told, that with 15lbs of boost you should be pushing 300hp. Tom Drake was making 285hp with 11lbs of boost. Not quite BB territory, but certainly SB.
Author:  Rick Covalt [ Mon Jul 14, 2003 2:28 pm ]
Post subject:  Turbo Power
One of the Moderators of this engine part of the board (Andrew wagner) just ran his car at the drags at the Chryslers at Carlisle event on Friday. My top secret spy contacts (My sons) went up on Saturday and the romur is that they heard a really different sound coming from the Dyno area. When they ran over, they said everyone standing around there was saying, "Man that things only a slant 6!!" Way to go Andrew! Keep up the good work. People are starting to notice.
It was good to see you again and maybe you can post some power results for us? Rumor is that you were over 220 Rear wheel HP. That's good with as little boost as you were running. It was also obvious from the drags that you have way more power than your stock tires can handle.
We were up on the hill and every time you came up, the people were all talking about your runs. Way to go! Let me know when your coming to Hagerstown again.
Rick Covalt
Author:  Bob D [ Mon Jul 14, 2003 7:49 pm ]
I'm sure that you can build a turbo SL6 with salvage yard parts. I did essentially that. Mine is a single turbo with an aftermarket AC, power steering, and power brakes and it all fits under my '69 Barracuda hood. I'm also sure that it doesn't equal a big block, but I would guess that it's equal to many small blocks; and it still handles real well.
Bob D
<imgsrc="http://hometown.aol.com/bbobbias/myhomepage/photo.htm"width=400>
Author:  welly225 [ Tue Jul 15, 2003 9:21 am ]
Hey, thanks for the feedback. So I'm not 100% crazy for thinking this can be done.
Why Is one turbo prefered over 2? Won't 2 smaller turbos spool up quicker then 1 larger one? Isn't this a benefit for reduced lag? The main reason for using the 2.2 turbos is since I already have them (and trying to keep as much Mopar under the hood as possible)
My plan as it stands now is to adapt an EFI to the / and get it running, work the bugs out, then add some forced induction once the motor is "proven".
Will the EFI swap described in the articles section be compatible with adding turbo(s) in the future? It seems reasonable as far as cost is concerned and not terribly complicated as long as it gives me the versatility later.
Author:  kesteb [ Tue Jul 15, 2003 12:51 pm ]
Some people have used a single 2.2 turbo, it works fine without any lag issues. At one point, Andrew was using a single Ford 2.3 turbo. The reason for 1 turbo is packaging concerns, there is not as much room as first appears on the drivers side of the engine bay.
For best results you should look for a turbo from a 3l or larger engine. This narrows the field down to a Nissan 280z, Toyota Supra, Buick or a Porsche. Some of these turbos are cheaper then others.
For the most part, I am going to emulate a 1983 Buick drawthru turbo setup. I have a water heated carb adapter, a Holley 650 spreadbore and a turbo from a Saab 2.3l. I most likely will fabricate an intake manifold, use a set of Dutra duals for the exhaust and I may replace the turbo with a Buick one (buick used a drawthru setup until '85, even with efi). This whole setup is envisioned to set right about where the carb is currently located, something like the \6 turbo setup that Hot Rod showed a while back. It should be interesting when done.
Author:  Al T [ Tue Jul 15, 2003 5:34 pm ]
Post subject:  Hello Gimli Welly
First week of July I spent across the lake from you at Grand Beach. If I come out next summer, maybe we can connect.
Author:  Bob D [ Tue Jul 15, 2003 9:04 pm ]
Welly,
Have you read this thread ( http://slantsix.org/forum/viewtopic.php ... ght=#24870 )? Many of your questions are answered there. (Be sure to scroll up and start at the top.)
Bob D
Author:  welly225 [ Wed Jul 16, 2003 5:50 am ]
Thank alot for the great info, I'm definitely doing this. The car is on the long term plan at the body shop so I've got lots of time to decide exactly how I want it to come together.
Al, if you come back to manitoba we should definitely connect. I don't know if you drove out this time but if you bring something to race we can probably spend a weekend at the track out in Gimli. I haven't been out there a lot because I don't have anything to race (YET) and just watching is like torture, but I've never seen any /s running. Somebody needs to teach those v8 boys a lesson.
I think I saw someone else on this forum who is from manitoba. Maybe we'll set up some sort of /6 support group retreat.
later
Author:  87Slant_sickness [ Wed Jul 16, 2003 11:23 am ]
Welly225
Nice to see another manitoban on the board :D, if you ever want to hook up i live in stony mountain, i'm always out at gimly on saturdays (figure we all know why ;)) and i've got a custom exhaust already made up and fabbed, if you need any help or advice i have a complete setup here thats ready to run (just dont have anyway of running it at the moment) and i'd love to show you around :)
My setup was custom fabbed for a 2.2L turbo which is what i'd like to start off with then later on move up to something alittle more aggressive...
Justin
P.S. Wanna sell one of those old blocks ;)?
Author:  welly225 [ Wed Jul 16, 2003 11:41 am ]
If you're looking for a block I can probably help you out. Some of the stuff parked in the back belongs to my grandpa and some uncles so I've got to make sure that I'm not selling anything I might need one day or something that belongs to someone else (We're a family of packrats but it comes in handy sometimes), I'm the only one interested in /s so there shouldn't be a problem there.
I'll definitely hook up with you at the track one weekend. My weekends are toast until mid august (bought house, moving) but after that no problem.
Nice chattin' with ya.
