| handleing problems for me too https://slantsix.org/forum/viewtopic.php?t=6279 |
| Author: | Guest [ Mon Jul 14, 2003 9:41 pm ] |
| Post subject: | handleing problems for me too |
in my 74 swinger, i have what feels like its got a bit of oversteer going on. when i get hauling A around a good corner, it almost feels like the back is going to come around any moment. it has addco bars front and rear with i bielive .890 bars if i remember. all that was in it when i bought the car. i also have 15x7 cop rims and 225/50r15 dunlop tires on all four corners. how can i plant the rear more? doin 70+ around a sweeet on ramp is a blast but the last thing i want to do is spin out. it feels like it will any moment. i have .920 bars i will be installing also so i know this will also change things. help please --chad |
| Author: | 225dart [ Mon Jul 14, 2003 9:42 pm ] |
sorry---forgot to sign in when i wrote that. --chad |
| Author: | Eric W [ Mon Jul 14, 2003 10:18 pm ] |
I'm not an expert, but I would try a larger sway bar on the front. |
| Author: | Doctor Dodge [ Tue Jul 15, 2003 1:25 am ] |
If you stiffen-up the front with bigger T. bars and anti-sway bar, that will help. The front wheels will want to "push" (understeer) as things stiffen-up. How are all the leaf spring bushings in back, worn leaf spring bushings makes the rear feel like it's going to break loose. DD |
| Author: | Dart270 [ Tue Jul 15, 2003 8:17 am ] |
Ditto what Doc said about leaf bushings. I found the poly rear leaf bushings helped out. Stiffening the front end would be good, but you could also remove the rear sway bar, or remove a leaf from each leaf pack to soften the rear. Either will reduce oversteer. Most A-body handling guys I know of, including me, do not run a rear sway bar. Have fun, Lou |
| Author: | 225dart [ Tue Jul 15, 2003 8:41 pm ] |
well, i know i need to redo the rear suspension. it needs new leafs and a good set of shocks all around. im very happy with how the car handles......i just want more. i will get these .920 bars installed soon i hope and report back. thanks for your help--i prob would have tried to stiffen the rear not knowing any better. --chad |
