It is currently Thu May 07, 2026 11:01 am
 Post subject: BBD rebuild kit
PostPosted: Sun Sep 02, 2018 8:32 am
The car won't idle, so I put a spare bbd I had in the garage and now it will idle but it doesn't seem to have the same upper end power as the one I took off, just seems sluggish above 2000rpm. I want to rebuild the one I took off but want to make sure I get the correct kit. The carb is stamped0-2378. Is there specific kits for early vs later carb or v8 vs/6? Pretty sure its a v8 carb. I need this by wed night at the latest to have it on and running for clay city.
 Post subject: Re: BBD rebuild kit
PostPosted: Sun Sep 02, 2018 9:09 am
You should check out Mikes Carb http://www.carburetor-parts.com/ I have bought several rebuild kits for my Carter BBDs. He has a long list of model numbers. And you can also call them and they can tell you which one will work.
66 dodge dart 270, 225ci, 3.7l, L6
Users browsing this forum: Ahrefs [Bot], Charrlie_S and 7 guests
