| 1 barrel vs 2 barrel https://slantsix.org/forum/viewtopic.php?t=62794 |
| Author: | RobbyII [ Mon Sep 03, 2018 6:29 pm ] |
| Post subject: | 1 barrel vs 2 barrel |
I recently purchased a 1985 D100 with slant 6, 84300 kilometers. It has the one barrel carb. It has poor oil pressure, sat for 27 years, and the person who I bought from just put in a battery and poured gas down the carb. It started, made some noises he could not describe,likely explains the poor pressure. My question is: I have a 2 barrel intake with a 2 barrel carb off another vehicle, runs just fine, but the vehicle is destroyed in an accident. The engine and transmission of 1985 truck are coming out tommorow to be disassembled and what ever needs done will be. I would like to know if going the 2 barrel is worth it. Have to buy new transmission linkage, throttle cable and maybe choke. Appreciate input. |
| Author: | SlantMills [ Mon Sep 03, 2018 9:30 pm ] |
| Post subject: | Re: 1 barrel vs 2 barrel |
In my opinion- The two barrel would be worth it, if the motor is healthy. WITH THAT BEING SAID.... your time and energy and money would be better spent diagnosing the poor oil pressure. First things first, get the factory service manual at least. If it sat for 27 years Good luck and happy slanting! -Josh |
| Author: | Jase [ Tue Sep 04, 2018 3:08 pm ] |
Do a search on oil pressure relief valve and spring, as they can gum up and reduce oil pressure... before pulling the whole motor out or apart, as they are known to stick open on occasion!!! Also There are cheaper ways to get a 2bbl than this following story suggests, but it does illustrate the gains a 2bbl carb offers with an optimized ignition, and good exhaust. So yes your 2bbl manifold is worth having!!! https://www.hotrod.com/articles/making- ... se-part-2/ |
